any one using this zigbee device? i have 3 of them installed under one zigbeemqtt instance, 2 of them are working ok but one of them is frequently stucking and spaming with messages, control and triggering of the device is not possible i need to restart it (current off/on) to get it working again. It happens every 2-3 weeks
2024-03-09 18:27:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:09+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:09+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:09+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:27:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:09+01:00","linkquality":96,"trigger":false}'
Info 2024-03-09 18:27:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:09+01:00","linkquality":92,"trigger":false}'
Info 2024-03-09 18:27:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:10+01:00","linkquality":92,"trigger":false}'
Info 2024-03-09 18:27:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:10+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:27:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:10+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:10+01:00","linkquality":112,"trigger":false}'
Info 2024-03-09 18:27:11MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:11+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:11MQTT publish: topic 'zigbee2mqtt/Repeater_1', payload '{"last_seen":"2024-03-09T18:27:11+01:00","linkquality":116,"update":{"installed_version":587753009,"latest_version":570447409,"state":"idle"},"update_available":null}'
Info 2024-03-09 18:27:11MQTT publish: topic 'zigbee2mqtt/Gate_1', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:11+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:15MQTT publish: topic 'zigbee2mqtt/Gate_2', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:15+01:00","linkquality":116,"trigger":false}'
Info 2024-03-09 18:27:23MQTT publish: topic 'zigbee2mqtt/switch_7', payload '{"last_seen":"2024-03-09T18:27:23+01:00","linkquality":100,"power_on_behavior":null,"state":"OFF","switch_type":null}'
Info 2024-03-09 18:27:30MQTT publish: topic 'zigbee2mqtt/Power_switch_1', payload '{"child_lock":"UNLOCK","current":1.23,"energy":101.48,"indicator_mode":null,"last_seen":"2024-03-09T18:27:30+01:00","linkquality":100,"power":154,"power_outage_memory":null,"state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-09 18:27:30MQTT publish: topic 'zigbee2mqtt/Power_switch_1', payload '{"child_lock":"UNLOCK","current":1.23,"energy":101.48,"indicator_mode":null,"last_seen":"2024-03-09T18:27:30+01:00","linkquality":104,"power":154,"power_outage_memory":null,"state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-09 18:27:38MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:38+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:38MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:38+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:27:38MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:38+01:00","linkquality":92,"trigger":false}'
Info 2024-03-09 18:27:39MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:39+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:27:39MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:39+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:39MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:39+01:00","linkquality":92,"trigger":false}'
Info 2024-03-09 18:27:40MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:40+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:27:40MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:40+01:00","linkquality":96,"trigger":false}'
Info 2024-03-09 18:27:40MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:40+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:27:40MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:40+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:41MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:41+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:27:41MQTT publish: topic 'zigbee2mqtt/Gate_1', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:41+01:00","linkquality":96,"trigger":false}'
Info 2024-03-09 18:27:44MQTT publish: topic 'zigbee2mqtt/switch_4', payload '{"last_seen":"2024-03-09T18:27:44+01:00","linkquality":104,"power_on_behavior":"previous","power_on_behavior_l1":"previous","state_l1":"OFF","state_l2":"OFF"}'
Info 2024-03-09 18:27:45MQTT publish: topic 'zigbee2mqtt/Gate_2', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:27:45+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:28:06MQTT publish: topic 'zigbee2mqtt/Power_switch_1', payload '{"child_lock":"UNLOCK","current":1.23,"energy":101.49,"indicator_mode":null,"last_seen":"2024-03-09T18:28:06+01:00","linkquality":96,"power":154,"power_outage_memory":null,"state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":231}'
Info 2024-03-09 18:28:08MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:08+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:28:08MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:08+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:28:08MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:08+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:28:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:09+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:28:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:09+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:28:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:09+01:00","linkquality":112,"trigger":false}'
Info 2024-03-09 18:28:09MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:09+01:00","linkquality":96,"trigger":false}'
Info 2024-03-09 18:28:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:10+01:00","linkquality":96,"trigger":false}'
Info 2024-03-09 18:28:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:10+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:28:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:10+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:28:10MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:10+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:28:11MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:11+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:28:11MQTT publish: topic 'zigbee2mqtt/Gate_1', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:11+01:00","linkquality":112,"trigger":false}'
Info 2024-03-09 18:28:15MQTT publish: topic 'zigbee2mqtt/Gate_2', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:15+01:00","linkquality":112,"trigger":false}'
Info 2024-03-09 18:28:25MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:25+01:00","linkquality":108,"trigger":false}'
Info 2024-03-09 18:28:25MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:25+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:28:25MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:25+01:00","linkquality":96,"trigger":false}'
Info 2024-03-09 18:28:25MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:25+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:28:26MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:26+01:00","linkquality":104,"trigger":false}'
Info 2024-03-09 18:28:26MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:26+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:28:26MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:26+01:00","linkquality":96,"trigger":false}'
Info 2024-03-09 18:28:27MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:27+01:00","linkquality":100,"trigger":false}'
Info 2024-03-09 18:28:27MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:27+01:00","linkquality":112,"trigger":false}'
Info 2024-03-09 18:28:27MQTT publish: topic 'zigbee2mqtt/Gate_3', payload '{"garage_door_contact":true,"last_seen":"2024-03-09T18:28:27+01:00","linkquality":104,"trigger":false}'
