I have a Aquark Mr. silent heatpump for the pool which is Tuya-based.
The pump is added in the Tuya app and in that app I can control the heatpump perfectly.
I also connected my Tuya account to Home Assistant and I can control lights etc. Also the heatpump is showing and turning on and off works, but changing the temperature doesn’t (also reading current temperature doesn’t show anything).
When changing the temperature I get this error message:
Kan service climate/set_temperature niet aanroepen. Entity climate.inverter_pool_heat_pump does not support this service.
The translation (done by me so the original message can be different:
Cannot call service climate/set_temperature. Entity climate.inverter_pool_heat_pump does not support this service.
Is this a known issue? I have read a topic (multiple) where this should just work:
