Tuya power plug integration does not show consumed energy (cumulative power)
I am testing the Tuya integration and how devices are supported.
I have just installed the Tuya integration in HA and I can see the Tuya ZigBee gateway and the two ZigBee plugs connected to it. So far so good. I am running latest version of everything on a RPi 4b
For the test I am using a Tuya ZigBee gareway connected to two Zigbee plugs. One of the plugs is a no-name plug from China (manufacturer _TZ3000_typdpbpg) and one is a Nous A1Z plug (manufacturer _TZ3000_ksw8qtmt).
Both plugs are correctly reported by the integration
If I look at the Nous A1Z device and display the hidden sensors, I have a screen like this
I can see sensors for Current, Power, Voltage, but I can’t see the Energy consumed (Total kWh). Is this a bug of the integration or I need to do something to show this very essential information?
I have the exact same problem with the other plug.
use Powercalc
This will not fix the tuya integration
Tuya swich power
ScreenShot_20220914182325
sensor.yaml
      sensor_tuya_watt:
        friendly_name: "Tuya Watt"
        value_template: "{{ (states('sensor.tuya_power') | float(0) / 1000)  | round(2) }}"
        unit_of_measurement: kWh
        device_class: energy
        unique_id: 2452716740006
  - platform: integration
    source: sensor.tuya_power
    unit_prefix: k
    round: 2
HA Total kWh
ScreenShot_20220914183013
Another power plug
ScreenShot_20220914184248
Where do you have your “sensors.yaml” file? I’m trying to make my Tuya to show wattage/power consumption, but can’t do it. Seen many articles about putting some extra code to the file “sensors.yaml” but my HA version looks like does not have this file.
Also @drcoolzic did you made something manually to show you Sensors of A1? As i see bit different way:
