Tuya problems
Why the Tuya v2 isnt working, detecting any device, and i can’t use the older Tuya integration?
Its setup correctly.
You can’t have both the HACS Tuya V2 and the builtin Tuya at the same time
I wasnt able to delete the older integration.
Now, i finally can, and did it.
But, the problem continues, in the Tuya V2, no devices detected.
Still the same
In your tuya api/cloud can you see your devices under device management on the overview page? I wasn’t sure what server I was on, and at first didn’t have the correct one enabled, had to edit the profile add all the servers and go find them.
So I guess step 1 is make sure you can see your devices in the Tuya IoT Platform
Have you followed the instructions here? - https://www.home-assistant.io/integrations/tuya/
This new Tuya integration isn’t very user friendly at the moment with a lot of faffing about setting up a Tuya cloud account. The instructions above are very clear though. Do NOT use an adblocker when signing up for a Tuya account as just about everything will be blocked as it was in my case.
Tuya BHT-02 thermostat not working with Tuya V2.
The thermostat is homeassistant and appears in Homekit but works ridiculously. So it is not possible to use BHT-002.
Tuya light switch is working normally.
Yes!
Yes, i did all the steps again and again, none worked.
I dont have any of these
Its just a door sensor (that i know that wasnt working in older tuya integration) and a switch lug, that was working well.
