Have some of these sensors and I have no sensors available i the Tuya integration
Any possibilities for support?
In the Tuya mobile app it has motion and battery.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.4.4",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.2",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Oslo",
"os_name": "Linux",
"os_version": "6.1.63-haos",
"supervisor": "2024.04.0",
"host_os": "Home Assistant OS 11.2.dev20231205",
"docker_version": "24.0.7",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"versatile_thermostat": {
"version": "6.2.3",
"requirements": []
"nordpool": {
"version": "0.0.14",
"requirements": [
"nordpool>=0.2",
"backoff"
"scheduler": {
"version": "v0.0.0",
"requirements": []
"zha_toolkit": {
"version": "v1.1.10",
"requirements": [
"pytz"
"hacs": {
"version": "1.34.0",
"requirements": [
"aiogithubapi>=22.10.1"
"alarmo": {
"version": "v1.10.0",
"requirements": []
"tibber_data": {
"version": "0.7.2",
"requirements": [
"pyTibber>=0.25.2"
"nodered": {
"version": "3.1.5",
"requirements": []
"localtuya": {
"version": "5.2.1",
"requirements": []
"meross_lan": {
"version": "5.0.4",
"requirements": []
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"codeowners": [
"@Tuya",
"@zlinoliver",
"@frenck"
"config_flow": true,
"dependencies": [
"ffmpeg"
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-device-sharing-sdk==0.1.9"
"is_built_in": true
"data": {
"endpoint": "https://apigw.tuyaeu.com",
"terminal_id": "1708792302922WqDwtV",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"id": "78363201d8bfc00ac849",
"name": "QNECT WI-FI PIR SENSOR",
"category": "pir",
"product_id": "j5jgnjvdaczeb6dc",
"product_name": "QNECT WI-FI PIR SENSOR",
"online": true,
"sub": false,
"time_zone": "+01:00",
"active_time": "2024-04-05T08:51:04+00:00",
"create_time": "2024-04-05T08:51:04+00:00",
"update_time": "2024-04-05T08:51:04+00:00",
"function": {},
"status_range": {},
"status": {},
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": []
"set_up": false,
"support_local": true
