Until Core version 2024.4, I was using a Tuya RGB and (cold and warm) White Bulb with no problem. When I update to 2024.4.1, I can only use the bulb in RGB, in both HomeAssistant and NodeRed.
Any ideas how can I control again the pure white? Thank you!
I’ve been having the same issue. So far the only solutions I’ve found consist of either using a smart device, using the tuya app, or using scenes. None of these have the ease of solution I’m looking for. Hopefully you have better luck and update here as well.
