I’ve just started using HA again after a break and now running on a RASPI and seems much better that the VM on Windows.
I’ve got a lot of Tuya devices and pretty well all have successful been linked into HA.
However, I have one device, a security alarm, which is found by HA, but has no controls so I cannot arm or dissarm it. All the sensiors connected to it are found and work.
I’ve looked in the diagnotic report and it would appear to have all the relevant data, but of course, I’m just not familiar enough to know if its correct.
Can any one help please?
Here is the diagnostics report:
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2024.7.4”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.12.4”,
“docker”: true,
“arch”: “aarch64”,
“timezone”: “Africa/Algiers”,
“os_name”: “Linux”,
“os_version”: “6.6.31-haos-raspi”,
“supervisor”: “2024.08.0”,
“host_os”: “Home Assistant OS 12.4”,
“docker_version”: “26.1.4”,
“chassis”: “embedded”,
“run_as_root”: true
“custom_components”: {
“hacs”: {
“documentation”: “Initial Configuration | HACS”,
“version”: “1.34.0”,
“requirements”: [
“aiogithubapi>=22.10.1”
“integration_manifest”: {
“domain”: “tuya”,
“name”: “Tuya”,
“codeowners”: [
“Tuya”,
“zlinoliver”,
“frenck”
“config_flow”: true,
“dependencies”: [
“ffmpeg”
“dhcp”: [
“macaddress”: “105A17*”
“macaddress”: “10D561*”
“macaddress”: “1869D8*”
“macaddress”: “381F8D*”
“macaddress”: “508A06*”
“macaddress”: “68572D*”
“macaddress”: “708976*”
“macaddress”: “7CF666*”
“macaddress”: “84E342*”
“macaddress”: “D4A651*”
“macaddress”: “D81F12*”
“documentation”: “Tuya - Home Assistant”,
“integration_type”: “hub”,
“iot_class”: “cloud_push”,
“loggers”: [
“tuya_iot”
“requirements”: [
“tuya-device-sharing-sdk==0.1.9”
“is_built_in”: true
“setup_times”: {
“null”: {
“setup”: 5.659199086949229e-05
“01J4D3Z20GQNKZ4F6CDBDWH2Y5”: {
“wait_import_platforms”: -0.11560203801491298,
“wait_base_component”: -0.003660715010482818,
“config_entry_setup”: 9.594136947998777
“data”: {
“endpoint”: “https://apigw.tuyaeu.com”,
“terminal_id”: “1722722256730aGExdL”,
“mqtt_connected”: true,
“disabled_by”: null,
“disabled_polling”: false,
“id”: “bf34da585f323481d2sjej”,
“name”: “Marine”,
“category”: “wg2”,
“product_id”: “yavjndceybck8uux”,
“product_name”: “Gateway”,
“online”: true,
“sub”: false,
“time_zone”: “+00:00”,
“active_time”: “2024-02-05T11:49:52+00:00”,
“create_time”: “2024-02-05T11:49:52+00:00”,
“update_time”: “2024-02-05T11:49:52+00:00”,
“function”: {
“master_mode”: {
“type”: “Enum”,
“value”: {
“range”: [
“disarmed”,
“arm”,
“home”,
“sos”
“delay_set”: {
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 1,
“max”: 181,
“scale”: 0,
“step”: 1
“alarm_time”: {
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 1,
“max”: 181,
“scale”: 0,
“step”: 1
“switch_alarm_sound”: {
“type”: “Boolean”,
“value”: {}
“switch_alarm_light”: {
“type”: “Boolean”,
“value”: {}
“alarm_ringtone”: {
“type”: “Enum”,
“value”: {
“range”: [
“1”,
“2”,
“3”,
“4”,
“5”
“switch_mode_sound”: {
“type”: “Boolean”,
“value”: {}
“switch_mode_light”: {
“type”: “Boolean”,
“value”: {}
“switch_kb_sound”: {
“type”: “Boolean”,
“value”: {}
“zone_admin”: {
“type”: “Raw”,
“value”: {}
“muffling”: {
“type”: “Boolean”,
“value”: {}
“switch_alarm_propel”: {
“type”: “Boolean”,
“value”: {}
“alarm_delay_time”: {
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 1,
“max”: 181,
“scale”: 0,
“step”: 1
“switch_mode_dl_sound”: {
“type”: “Boolean”,
“value”: {}
“master_state”: {
“type”: “Enum”,
“value”: {
“range”: [
“normal”,
“alarm”
“factory_reset”: {
“type”: “Boolean”,
“value”: {}
“zone_attribute”: {
“type”: “Enum”,
“value”: {
“range”: [
“disarmed”,
“arm”,
“home”,
“24h”,
“delay”,
“others”
“alarm_volume_value”: {
“type”: “Integer”,
“value”: {
“unit”: “”,
“min”: 1,
“max”: 9,
“scale”: 0,
“step”: 1
“doorbell_ringtone”: {
“type”: “Enum”,
“value”: {
“range”: [
“1”,
“2”,
“3”,
“4”,
“5”
“status_range”: {
“master_mode”: {
“type”: “Enum”,
“value”: {
“range”: [
“disarmed”,
“arm”,
“home”,
“sos”
“delay_set”: {
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 1,
“max”: 181,
“scale”: 0,
“step”: 1
“alarm_time”: {
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 1,
“max”: 181,
“scale”: 0,
“step”: 1
“type”: “Boolean”,
“value”: {}
“type”: “Boolean”,
“value”: {}
“alarm_ringtone”: {
“type”: “Enum”,
“value”: {
“range”: [
“1”,
“2”,
“3”,
“4”,
“5”
“type”: “Boolean”,
“value”: {}
“type”: “Boolean”,
“value”: {}
“type”: “Boolean”,
“value”: {}
“charge_state”: {
“type”: “Boolean”,
“value”: {}
“zone_admin”: {
“type”: “Raw”,
“value”: {}
“muffling”: {
“type”: “Boolean”,
“value”: {}
“alarm_msg”: {
“type”: “Raw”,
“value”: {}
“type”: “Boolean”,
“value”: {}
“type”: “Integer”,
“value”: {
“unit”: “s”,
“min”: 1,
“max”: 181,
“scale”: 0,
“step”: 1
“type”: “Boolean”,
“value”: {}
“master_state”: {
“type”: “Enum”,
“value”: {
“range”: [
“normal”,
“alarm”
“master_information”: {
“type”: “String”,
“value”: {
“maxlen”: 255
“factory_reset”: {
“type”: “Boolean”,
“value”: {}
“zone_attribute”: {
“type”: “Enum”,
“value”: {
“range”: [
“disarmed”,
“arm”,
“home”,
“24h”,
“delay”,
“others”
“type”: “Integer”,
“value”: {
“unit”: “”,
“min”: 1,
“max”: 9,
“scale”: 0,
“step”: 1
“type”: “Enum”,
“value”: {
“range”: [
“1”,
“2”,
“3”,
“4”,
“5”
“abnormal_list”: {
“type”: “Raw”,
“value”: {}
“status”: {
“master_mode”: “disarmed”,
“delay_set”: 60,
“alarm_time”: 180,
“switch_alarm_sound”: true,
“switch_alarm_light”: true,
“alarm_ringtone”: 1,
“switch_mode_sound”: true,
“switch_mode_light”: true,
“switch_kb_sound”: false,
“charge_state”: true,
“zone_admin”: “AAEABgEACDA5NkUwMkZGAQAIMTExRTAzRkYBAAhFRTk0MDJGRgEACDlBNkUwMkZGAQAIMTg5NzAyRkYBAAg0Nzg5MDJGRg==”,
“muffling”: false,
“alarm_msg”: “eyJhbGFybV9saXN0IjpbeyJub2RlSWQiOiJDQTNGQzBGRiIsImRwcyI6eyIxIjoiQkYifX1dfQ==”,
“switch_alarm_propel”: true,
“alarm_delay_time”: 40,
“switch_mode_dl_sound”: true,
“master_state”: “normal”,
“master_information”: “”,
“factory_reset”: true,
“zone_attribute”: “disarmed”,
“alarm_volume_value”: 8,
“doorbell_ringtone”: 1,
“abnormal_list”: “eyJhYm5vcm1hbF9saXN0IjpbeyJub2RlSWQiOiJGRjdEMDJGRiIsImRwcyI6eyIxIjp0cnVlfX0seyJub2RlSWQiOiI5QTZFMDJGRiIsImRwcyI6eyIxIjp0cnVlfX1dfQ==”
“home_assistant”: {
“name”: “Marine”,
“name_by_user”: null,
“disabled”: false,
“entities”:
“set_up”: false,
“support_local”: true
