Hi I would like to expose a small malfunction with a temperature / humidity sensor ST-TH01 tuya
, in the application for “smart-life” for smartphones everything works regularly but on the home assistant it only reports the temperature , there is no humidity and battery level, how can I solve ? i have aquara MI T / H sensors these work fine.What integration are you using ?
I use Tuya Smart integration with this Gateway
