Hi All
this is my first post on Home Assistant Forum, sorry if there is any mistake on category selection
I Need your help for a very big headhake issue that I’m facing.
I have purchased a Tuya Smrat Meter (directional) on Aliexpress (same one that you can find on AMZ), that should read electricity passing through a wire. https://it.aliexpress.com/item/1005005455143742.html?spm=a2g0o.order_list.order_list_main.17.1bea3696QY8CyR&gatewayAdapt=glo2ita
I placed the magnet around the Load wire (Brown) coming from by electricity company meter.
And here start the problem.
I have a solar installation that produce up to 600W. I Leave in an apartment with a terrace, so i choose a Plug & Play system. Works amazing and I love it.
It is smart and integrated with Home Assistant, so I can import reads of production. This part works fine just fine.
But.
Importing in home assistant Tuya Smart Meter I have noticed an issue
If the solar produce more electricity than the House is requiring, Tuya meter read positive electricity, like the house is requiring from the grid, but it is not like this. If I go to the “meter” from the electrcity company, it read “0” since housw is using solar power.
Example.
Solar is producing 500W
My house is requiring 200W, Tuya smart meter reads 300W positive.
I have created an helper on Home assistant.
Tuya - Solar = Home consumption. Perfect… NOT
If the house is requiring less power than Solar production, my Helper reads negative values. So It is like House is not using any elctricity and the difference goes into the grid
This is my helper
template:
- sensor:
- name: “Consumo Totale Casa”
unit_of_measurement: “Wh”
device_class: energy
state_class: total_increasing
state: “{{ (states(‘sensor.consumo_casa’) | float(0) - states(‘sensor.shellyplug_s_80646f8259f7_power’) | float(0)) / 1 }}”
icon: mdi:transmission-tower-export
It is like Tuya smart meter is reading also electricty that solar panel are producing and the house is not using.
It is been sold to me as a directional meeter, there’s also an arrow on the magnet to indicate the electricity flow direction. I have checked and I have installed correctly
How can I configure it as reading only for real grid consumption?
