Assuming this is a wifi plug, did you check signal strength e.g. via the smartlife app? The non-pathway plugs I have are far from good wrt distance to the wifi-router
The short distance is not a guarantee. The one that was troublesome for me is below 5m from the router, no blocking elements in between and shows -79dB which is a joke of course wrt to signal strength. The other three are just fairly better (less bad) But anyhow, if yours is fine on this one, did you check the tuya log itself?
Yep, but far from bad. The 3-times ‘OFF’ before that (in a 1 minute span) are also odd but within this 2-day log I myself would not be too concerned, but I would when seeing your initially posted logs.
If it is not the device then it probably is HA intergation (re/dis)connecting with Tuya…that goes beyond me
Not even saying localtuya would help but you might try that…the setup with project a.o. is slightly challenging but … a possible alternative
That is what I meant when I was referring to your original post, seems HA / Tuya integrations has issues…hence suggesting tuyalocal but no guarantee. As no-one else chimes-in, this could also be seen as a single-device issue.
There are soo many ‘tuya’ devices out there, I have already 3 ‘brands’ and no way to get one single view on them…and then there are in-brand differences over time too.
For now I can only propose to try localtuya unless someone else knows more, Worse-case…it will not work. Also in other protocols like zigbee there are devices that state to do something (e.g. power consumption) but in reality…nop.
