“Tuya” was not tagged in Tuya smart water timer (unsuported) . I just wanted to make sure this was on the someone’s radar.
It would be very helpful to have support for my Tuya smart water timer.
switch Boolean
"{true,false}"
battery_percentage Integer
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
time_use Integer
"unit": "s",
"min": 0,
"max": 2592000,
"scale": 0,
"step": 1
weather_delay Enum
"range": [
"cancel",
"24h",
"48h",
"72h"
countdown Integer
"unit": "s",
"min": 0,
"max": 86400,
"scale": 0,
"step": 1
work_state Enum
"range": [
"auto",
"manual",
"idle"
smart_weather Enum
"range": [
"sunny",
"cloudy",
"rainy"
use_time_one Integer
"unit": "s",
"min": 0,
"max": 86400,
"scale": 0,
"step": 1
syepes
(Sebastian YEPES)
June 12, 2023, 8:12pm
2
Please give this integration feature some love
home-assistant:dev
← wilds:device_sfkzq
opened 11:08AM - 03 Apr 22 UTC
## Breaking change
None
## Proposed change
TUYA Integration: Added suppor… t for Moes Smart Water Timer
https://user-images.githubusercontent.com/795322/135816004-3268df58-b7e4-48d2-bbf7-cb40f481b234.jpg
https://www.moeshouse.com/products/smart-bluetooth-sprinkler-water-timer-with-rain-delay-filter-washer-programmable-irrigation-timer-with-automatic-and-manual-watering-for-standard-outdoor-garden-faucet-lawn-bluetooth-hub-required-for-irrigation-history
## Type of change
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [X] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
None
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [X] The code change is tested and works locally.
- [X] Local tests pass. **Your PR cannot be merged unless tests pass**
- [X] There is no commented out code in this PR.
- [X] I have followed the [development checklist][dev-checklist]
- [X] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [X] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
syepes
(Sebastian YEPES)
September 14, 2023, 1:00pm
3
Can someone please help review and validate this integration. We have been waiting and waiting months just for a really small modification, that could enable lots of devices.
Pleas up vote this change:
home-assistant:dev
← syepes:tuya-water
opened 11:32AM - 22 Jun 23 UTC
## Breaking change
None
## Proposed change
Adds support for Smart Water Tim… ers from Tuya
This an updated version of https://github.com/home-assistant/core/pull/69188 and adds only the working elements
R4238 Smart Irrigation Control
https://wooxhome.com/products-c10/other-c4/woox-r4238-smart-garden-irrigation-control-p107
TUYA Integration: Added support for Moes Smart Water Timer
### Standard Status Set
<img width="491" alt="CleanShot 2023-09-08 at 12 42 47" src="https://github.com/home-assistant/core/assets/333081/03a0055d-833b-465f-9b8d-dee12040f8b7">
<img width="446" alt="CleanShot 2023-09-08 at 12 43 18" src="https://github.com/home-assistant/core/assets/333081/1cf45fdc-b18f-48af-bd13-e65acc1f06a5">
## Type of change
- [ ] Deprecation (breaking change to happen in the future)
None
- This PR fixes or closes issue: fixes #69188
- This PR is related to issue: https://github.com/home-assistant/core/pull/69188
- Link to documentation pull request:
## Checklist
- [ ] There is no commented out code in this PR.
- [X] I have followed the [perfect PR recommendations][perfect-pr]
- [X] Tests have been added to verify that the new code works.
- [X] I have reviewed two other [open pull requests][prs] in this repository.
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
