This doesn’t change anything, during pairing, I was close and it slows link quality 220. I tried re-pairing several times but result is always the same.
Tuya is famous for selling the same device with different internal vendor names. Maybe the herdsman convertor needs to be updated.
Better file an issue here:
Tried all that just to make sure. Deleted device, restarted whole HA server, added device - no change.
Batteries are brand new Energizer Industrial, measured 1.6V each.
I guess the problem is that this device introduces itself not as Tuya, but some other manufacturer. This is zigbee2MQTT log when pairing:
|[2024-06-21 19:59:05] info: |z2m: Successfully interviewed '0xa4c138bca1aa027a', device has successfully been paired|
|[2024-06-21 19:59:05] warning: |z2m: Device '0xa4c138bca1aa027a' with Zigbee model 'TS0601' and manufacturer name '_TZE204_myd45weu' is NOT supported, please follow https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html|
I had the same issue with 2 of _TZE204_myd45weu. Just updated zigbee2mqtt to 1.39.0 and both have been successfully paired. I planted the sensors in the garden but both always show the soil moisture at zero. How can I debug the issue?
Good to see you have it solved. I can also confirm that my device works with the new zigbee2mqtt update. Until the update I used it with the zigbee2mqtt Edge version.
Just in case you may find this useful: I also noticed my sensor showing 0% for some time, but the reason was that I put it in a spot where it didn’t have zigbee signal reception. There were no errors, just no data updated. After moving it to another spot it works fine.
