I’ve got two tuya wall switches (TS0002). One of the switches is working fine, the other switch connects fine. But after a while the zigbee2mtqq shows that the switch is not recognizable anymore. After I removed the switch from the zigbee2mtqq portal, put the switch back in pairing mode, the switch will pair again.
After a few hours the same is happening. What can be the case and the solution? The switch worked fine for a couple of weeks.
