Ako imaš dva ili više prekidaca koji kontroliraju jedno svjetlo to ti je spojeno kao izmjenični prekidač. Da bi ti to radilo sa smart prekidačima vjerojatno ćeš morati pozvati električara da prespoji žice. Funkcionira tako da imaš jedan prekidač koji je Master, dakle fizički kontrolira svjetlo, a ostali su slave prekidaci.
Master prekidač je spojen na L, L1, N a slave su spojeni ako se dobro sjećam L i N.
Oni se mogu povezati u ha tako da funkcioniraju kao jedan prekidač. Ja koristim automatizaciju ako upalis prekidač 1 onda upali prekidač 2, 3 itd. Isto za gašenje.
We can only support one language here, and that language is English. We appreciate that not everybody can read and write it, but there are a wide range of options out there . We chose this language since it’s known to the moderators and developers, and also one of the most widely known languages.
Yes. Master switch is physically controling the light. Slave switches doesn’t physically control anything. They just need power to be on. That’s why they need L and N wire connected to them.
Slave switches are basically dumb switches that need and automation to toggle lights on off
