Hello there, during last weeks I’m getting a lot of error with my tuya devices (added using standard component), but I can’t really see what’s going on… can someone help ? As you can see there are a lot of different errors:
Log Details (ERROR)
Mon Jun 17 2019 01:57:37 GMT+0200 (Ora legale dell’Europa centrale)
Update for switch.80241621840d8e4b51c0_1 fails
Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 159, in _new_conn (self._dns_host, self.port), self.timeout, extra_kw)
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 57, in create_connection for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo for res in _socket.getaddrinfo(host, port, family, type, proto, flags): socket.gaierror: [Errno -3] Try again During handling of the above exception, another exception occurred:
Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn conn.connect() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 301, in connect conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6d2e61f0>:
Failed to establish a new connection: [Errno -3] Try again During handling of the above exception, another exception occurred:
Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen _stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 398, in increment raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='px1.tuyaeu.com', port=443): Max retries exceeded with url: /homeassistant/skill (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6d2e61f0>: Failed to establish a new connection: [Errno -3] Try again'))
Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 220, in async_update_ha_state await self.async_device_update()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 379, in async_device_update await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, self.kwargs)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/tuya/__init__.py", line 151, in update self.tuya.update()
File "/usr/local/lib/python3.7/site-packages/tuyapy/devices/base.py", line 43, in update self.obj_id, 'QueryDevice', namespace='query')
File "/usr/local/lib/python3.7/site-packages/tuyapy/tuyaapi.py", line 134, in device_control response = self._request(action, namespace, devId, param)
File "/usr/local/lib/python3.7/site-packages/tuyapy/tuyaapi.py", line 159, in _request json = data
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 116, in post return request('post', url, data=data, json=json, kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request return session.request(method=method, url=url, kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request resp = self.send(prep, send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send r = adapter.send(request, kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='px1.tuyaeu.com', port=443): Max retries exceeded with url: /homeassistant/skill (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6d2e61f0>: Failed to establish a new connection: [Errno -3] Try again'))
Log Details (ERROR)
Mon Jun 17 2019 10:42:53 GMT+0200 (Ora legale dell’Europa centrale)
File "/usr/local/lib/python3.7/site-packages/tuyapy/tuyaapi.py", line 161, in _request response_json = response.json()
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 897, in json return complexjson.loads(self.text, kwargs)
File "/usr/local/lib/python3.7/site-packages/simplejson/__init__.py", line 518, in loads return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 370, in decode obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 400, in raw_decode return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Thanks in advance…
