Tuya switches with Conbee 2
My current setup is a conbee 2 stick on a pi 3 connected to a few ikea lamps. I’m planning to replace existing switches with smart ones. As I don’t want to clutter my wifi, I thought of using zigbee switches like these
Do they work with the conbee 2?
I am also interested in that.
Zigbee works somehow, i only haven’t figured out to pair them to HA conbee.
What happened to me, i had to re-initialize my tuya, and apparently it got paired accidentally with my motion detector, as the where in the same room…
It was a pain in the a*s to get it unpaired again🤔
So if anyone managed to get it paired with conbee, let me know :yum:
do you have any success on integrating Tuya sensors into HA?
I have Tuya Zigbee Temperature and humidity sensor, but currently can not use it with my Conbee 2 on Rasberry Pi 4 Home assistant.
Do you know any solution for it? Thanks
Did you manage to make the integration work between Tuya sensor & Conbee II ?
I have a Tuya door sensor and unable to connect to conbee II :frowning:
