I recently bought a Tuya TS0601 (_TZE200_a8sdabtg) from AliExpress and periodically (~every 15 minutes) I am getting weird/incorrect readings. Specifically the temperature will drop to 32 degrees Fahrenheit and the humidity will jump to 655.4%. When the sensor is not reporting 32 degrees/655.4% humidity the readings appear to be correct.
Here is a graph showing some of the incorrect readings:
And here is the device signature:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4742, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0302",
"input_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0402",
"0x0405"
"output_clusters": [
"0x0003"
"manufacturer": "",
"model": "TS0601",
"class": "zigpy.device.Device"
Iâm curious if anyone else has experience with something like this or has any tips for debugging
