could you help me to integrate the tuya temperature sensor.
This is the sensor, but local tuya doesn’t show the sensor.
Thanks in advance.
Thanks in advance.
Local tuya? Try their repo GitHub - rospogrigio/localtuya: local handling for Tuya devices
i use this integration but the senors are not shown. Are there other possibilities?
Does anyone know a solution how to fix the problem?
Local Tuya is not a home assistant integration
It is a custom integration with its own github repo and support channel
That’s why I suggested you ask there.
These battery-powered devices are not supported by LocalTuya. It is possible to add the device, but it will be generally unavailable, as it awakens only to communicate with its cloud server.
By pressing CONFIGURE in the LocalTuya integration a few seconds after re-inserting batteries in a TS0201 Temperature Humidity sensor, the device id appears in the available list. Since it is not a supported device, one must manually add the data points (DPs) separated by commas. For the Temp Humidity sensor these are 1,2,4 (temperature, humidity, battery).
Thanks for your answers! I have installed tuya not local. And now it works.
But unfortunately not local.
You can get this device supported if you do 2 things:
Took me quite some time to understand this and get it working in HA
Peter
Hi. After reading quite a few posts regarding the same topic, I have just added T&H sensor configuration into “core.config_entries” manualy. You can even skip some key/values, as once you add this record, later on you would be able to configure properly via integration UI (Integration → Local tuya → Configure → Reconfigure existing device
my json extract for the sensor:
"bf...kzp": {
"friendly_name": "temperature_tuya_local",
"host": "192.168.1.148",
"local_key": "DViw.....O",
"protocol_version": "3.4",
"enable_debug": false,
"scan_interval": 120,
"device_sleep_time": 300,
"entities": [
"friendly_name": "T & H Kids room",
"entity_category": "diagnostic",
"unit_of_measurement": "°C",
"device_class": "temperature",
"state_class": "measurement",
"scaling": 0.1,
"id": "1",
"platform": "sensor",
"icon": ""
"product_key": "55...kzp",
"device_id": "bf...kzp",
"node_id": null,
"dps_strings": [
"1 ( value: 276 )"
Hi Ian - do you think you could list out an “idiots guide” on how to add this JSON code manually into HA so I can get my devices to work? They connect & work perfectly in the SMART LIFE app but I cant get then into my HA, probably because of the unit going to sleep as previously mentioned in this thread. I’d like to give your JSON approach a go but I’m not sure how to go about editing the config file. Any help would be greatly appreciated.
Where can I find pin 9 on the chip on the board? Could you help me based on a photo? Thanks in advance!
EDIT: I found a documentation based on the cb3s module.
Hi palbeda,
first of all thanks for this very useful hack. My question is do you measure the battery duration with this mod?
in other words, I need to have a power supply 3.3 V or it is enough to supply the device with batteries?
Franco
