Tuya termostat set from °C to °F
Hi, i have a problem with Smart wifi Thermostat, the scale of temperature in app tuya is set on °C and in home assistant integration in °F, and not there is no possibility to change it like in the sensors, with the old version this bug was not present.
You could create a sensor that converts the value from ºC to ºF. Place this in your config file:
    sensors:
      sensor_tuya_thermostat_temp_C:
      entity_id:
      - sensor.tuya_thermostat
      unit_of_measurement: '°F'
      value_template: >
        {{((states('sensor.tuya_thermostat')* 9 / 5)+ 32)|round(1)}}
sensor.tuya_thermostat is your current tuya sensor, and then,
sensor_tuya_thermostat_temp_C is the converted value sensor.
Hi Postixer,
Can you set it in the Tuya app, it may cascade thru to HA.
Not a FR, moved.
