Did anyone try to add below device on zigbee2mqtt?
Tuya Zigbee Thermostat HC-T010-TYZB
Check here to seee if supported by some of the Zigbee integrations
Thanks, but I wouldn’t ask to community if it woild appear in any of the known lists. Is it a clone of any of those?
Did you buy it already ? If so, as what device is it detected ?
No, it was before triggering purchase.
But it quite looks the same than all the BHT clones apart the LCD screen.
I was wondering as the ad says program if of 6 temp slots per day, whereas usual BHT clones has 4 only per day… (over 5+1+1 days)
I installed and all right. The matter is that the clock works bad. I put an hour and every day the time earns 10 minutes. It is crazy for the programation. Do you know how it can be solved? Tx
