Tuya thermostat with wrong temperature
Hi guys,
I’ve two tuya thermostat that show me a wrong temperature. ( below an example)
there is a possibility to adjust the value with right one?
Actualy room temperature should be 27,5 °C
with a set point of 15.0 °C
consider that I’ve already tried Tuya V2 but issue still the same
Version of Home Assistant: 2024.09
thanks for your help
Luca
I had the same problem and using hass-localtuya custom integration to define my own entity. It allows you set the scaling factor for measured and target values.
Hi luca120,
You can also plug the value you get into the compensation integration or into a template sensor and use the result of that in your thermostat.
Finally I got de decision to desolder the Wifi module and proceed with Link I know is a drastic stuff :smiley: but has been more easily for me :smiley:
thanks to all
Luca
