Hi guys.
I’ve tried to manage controlling my Tuya TRVs by automations by it doesn’t work at even good level… Sometimes it doesn’t triggers, sometimes it triggers too often and when i put heating on it opens valve for 100%. I want to use automatic mode (like in thermostat card) with different temperatures for day and night. Where the valve is adjusting its open level to actual temperature in the room - if its lower than desired - open valve a little bit more, if it’s higher - close it. Automatic mode from thermostat card would work well, but it’s using tuya’s internal temperature sensor which shows much higher temperature than it is actualy in the room. Is there any way to change it to external temperature sensor? To open-close valve basing on the temperature from different sensor? I would appreciate any help,because i have no idea how to do it…
Thanks in advance!
