Tuya TRV control Tado
I’ve recently bought a tado wall thermostat and i wanted to tinker around with integrating it into home assistant. I already had some TRV’s from Tuya which i use to control the temperature in each seperate room. Right now the only way to do so is by turning up the heater and controlling each room, but i’d like to use the Tuya TRV in the same way as the Tado TRV does. This gives a signal to the wall thermostat to turn op the heater automatically when there is a demand for heat in a room.
I’ve tried to work with automation in HA, but i can’t get it to work. I do get a trigger when the Tuya TRV requires heating, but i can’t find the action it needs to trigger to get the hot water flowing. Can someone help me with this?
Thanks a lot!
Hi, did you get this to work? :slight_smile:
