hainfelder
(Hainfelder)
6
Is there a way to set valve position directly?
I did not find a way to set the valve position directly. (it would be great though - then all the logic could be programmed in HA)
But user @gavlexx may have found a way. See his post here on HAC. He replaced the NTC (temperature probe) with a fixed resistor.
Not confirmed.
Only for better SEO
Tuya TS0601 - Moes HY368 TRV - Moes HY369RT, SHOJZJ 378RT, Silvercrest TVR01, Immax 07732B, Evolveo Heat M30 - set valve position, Best Practice
