Tuya TS0601 - Moes HY368 TRV - Best Practices - Summary Thread
Hey to Everybody,
this thread aims to collect Best Practices and Solutions for
Link to Zigbee Devices
other white label versions according to ZigBee HP:
Moes HY369RT, SHOJZJ 378RT, Silvercrest TVR01, Immax 07732B, Evolveo Heat M30
You are welcome to share your own experiences and questions!
At the moment I am using five of these in my second heating season with HA. So I am still experimenting to tweak them to their best. (not yet there).
There are tons of threads scattered all over the internet - but no central place to collect things and ideas.
Hoping for many people to join - i will try to summarize posts from time to time. Do not know how long my own posts are editable though.
Link to the supplied manual in .pdf
Link to a german manual on brainzap.de
Valve still heating / letting hot water through even though its closed
Little grey plastic ring
Out of the box the TRVs come with a grey plastic ring, that has to be removed for most valves. Check if you removed the ring when you installed the TRV on the radiator - its possible to mount the TRV with the grey ring, but then the valve can´t be closed
Found here
Maybe rerun adaptation of the TRV
This is function “Ad” when setting up the TRV.
Putting a small coin in between actuator and valve pin
Some people had success by adding a small coin (and some grease) in between
Found here
If this is not working, than:
Setting Valve Seal Type to “hard” in Advanced Settings on TRV
There is an option in the Advanced Settings of the TRV
Can be set to:
0: Soft Seal
1: Hard Seal
Video on youtube to set hard seal
Presumably puts more strain on the components
Only for better SEO
Tuya TS0601 - Moes HY368 TRV - Moes HY369RT, SHOJZJ 378RT, Silvercrest TVR01, Immax 07732B, Evolveo Heat M30 - Still heating even if closed, Best Practice
TRV doesn´t stop heating although its already warmer than set
Happened to me -
Automation need to set Mode of the TRV to AUTO not on HEAT.
HEAT forces the TRV to be fully open - no matter of the set temperature
Only for better SEO
Tuya TS0601 - Moes HY368 TRV - Moes HY369RT, SHOJZJ 378RT, Silvercrest TVR01, Immax 07732B, Evolveo Heat M30 - Doesn´t stop heating, Best Practice
TRV is not letting water through / is not heating despite Valve Position Open / at 25%
Happened to me - solution / Workaround for the moment:
When TRV position is set to 25% then slightly loosen the big grey mounting screw until there is water flowing. Check if the TRV still seals the valve right when back on 0% / closed.
Not sure if I will stay with this - maybe cutting of 2mm of the grey ring that was delivered with the TRV …
Only for better SEO
Tuya TS0601 - Moes HY368 TRV - Moes HY369RT, SHOJZJ 378RT, Silvercrest TVR01, Immax 07732B, Evolveo Heat M30 - Not heating although open, Best Practice
Advanced TRV settings: Control type of valve :question: :question: :question: :question:
In Advanced Options of the TRV you can choose between three “control types” : 0 PID, 1 FLOAT, 3 ON/OFF.
They greatly change the behavior of the TRV.
Still very unclear - experience needed - What are you using?
At last edit I was 5 days into experimenting with the PID control type and collecting experience, so I will update this section more often.
0: PID
What is a PID?
Generally speaking a PID Controller is a mathematical calculation, that tries to calculate changes in the past into future changes and switches Heating accordingly. Normally you can change the PID parameters to adapt to your specific conditions (e.g. heat loss,heating power, heat preserved in the radiator once hot). Sadly the PID parameters are factory set and not accessible.
Additional info: What is an PID?
(my experience with PIDs comes from tinkering a PID to my espresso machine)
Pro:
Valves do open and close in 5%-steps.
  • at the moment i am set at 18,5° C for a target temp of 20,5° (Reason behind probably the pre-programmed PID parameters, that are meant for a standard (asian?) room, that is loosing heat very fast (my thinking at the moment))
  • once the TRV has decided to open to a position (lets say 50%) it seems to close only in steps of 5% but only every few minutes. This sometimes produces overheating (at least in my room).
  • if windows open detection is running and for example a window open temp is set, that is way lower than usual comfort temp, then closing the window and going back to comfort temp (e.g. 18,5°->14°->18,5°) makes the valves open quite a bit → regardless of actual temp → overheating
1: FLOAT
Did not test this out yet myself - scarce information available
2: On/Off
Seems to work fine - Despite the name, this setting is more than on/off - Stepping is done in steps of 25%, not 5% with the PID setting - Probably the TRV has set valve position linked to temp difference between set and curren temp.
In case your TRV-Valve-combination does not let water through at 25% this control type won´t open more. I will just wait for hours It won´t open the valve any more, when there is no heat coming though. It will do so, when the current temp is much lower that the set temp.
@flixx (See his post) has lower temp invariances with this setting instead of PID
Only for better SEO
Tuya TS0601 - Moes HY368 TRV - Moes HY369RT, SHOJZJ 378RT, Silvercrest TVR01, Immax 07732B, Evolveo Heat M30 - Control type of valve, Best Practice
Is there a way to set valve position directly?
I did not find a way to set the valve position directly. (it would be great though - then all the logic could be programmed in HA)
But user @gavlexx may have found a way. See his post here on HAC. He replaced the NTC (temperature probe) with a fixed resistor.
Not confirmed.
Only for better SEO
Tuya TS0601 - Moes HY368 TRV - Moes HY369RT, SHOJZJ 378RT, Silvercrest TVR01, Immax 07732B, Evolveo Heat M30 - set valve position, Best Practice
ZHA or ZigBee?
Many people seem to have moved from ZHA to ZigBee with these TRVs. Better support and no need of custom quirks
Advanced TRV settings: Heating Start/Stop Hysteresis
Hysteresis delays the reaction.
You can set the Hysteresis from 0.5°-1.5°
From the factory it is set to 1°. → will always heat until +1°
Most people recommend to set it to 0.5°
See also manual.
Still heating when closed. Tried adjusting real tight, no plastic ring seemed tight but after hours of 0% opening:
Hey!
Did you set “Hard Seal” ?:
Can be set to:
0: Soft Seal
1: Hard Seal
Hi Guys !
Please, let me ask two details :
  • did you find you, what VALVE CONTROLLING METHOD “FLOAT” means ? PID and ON/OFF is clear, i just cannot find out what FLOAT means
  • what is the lowest positive valve position you can get please ? “0” means closed, besides this i was able to get/catch and see 25% as the lowest valve position value. Is it possible to get the valve open only for couple of percents (maybe 5%-10%) ?
Thanks !
Thanks for sharing all these informations about that TRV.
Setting the hysteresis to 0.5°C helped me. But valve sometimes mechanically doesn’t close fully even if 0% is set. I watched the video about “hard seal” and tried to set it on mine. But I don’t have the “C” option in setting menu. It ends at B and next is 1, 2, …
The linked manuals also don’t show the “C” option
I’m using Z2M and no firmware update is available.
Any suggestions why some of you have this option? :slight_smile:
This happened to me when I dialed the flow through the radiator too low on the radiator valve. When I increased it back to normal, it started flowing at 25% opening. Check this video How TRV works so you know what dial Im talking about. All new radiator valves I’ve seen have some flow setting like this.
anyone has solution where the setting temp is actually the temperature the room is at? I set 20C and ended up with about 21-23C. I imagine, if setting 20C I should have the room at 19-21C, at least that’s how all my previous thermostats worked.
No Harm done in trying out! If you do, please report
Yes. In PID Mode you get 5% steps. If I remember right only on the way down (closing).
I have seen different manuals with different options. What “C” option are you referring to?
I had an firmware update recently. But I do not remember the version number. think it was from 75 to 78 ???
Do you mean, that your room is overheating?
Yes, I have same problem.
When I set setpoint to 21, trv is opened til 24 plus minus and then close. So as I read on some topics, trv has some FW hysteresis. And I would like to repair it.
I have two batches of moes hy368 trv one from 2021 and second from 2024, where first is working properly but second not. First difference is hard and soft close settings.
Is there anybody who recognised how to fix it? Is possible to flash different firmware?
Thank you.
Until now I have always been able to solve incomplete closure problems by setting the valve to high temp (valve open to release pressure from the pin), then tightening the TRV more to the CV and the redo a calibration cycle (power off then on again, press menu multiple times until “ad” appears and then one more time). I guess at some point the TRV is so close to the pin that full closure becomes unavoidable. Maybe some WD40 on the pin to lubricate movement a little?
Problem I have is the motor in the TRV dying after a few years (E1 error or plainly saying it’s 100% open while it is not one bit open). Until now I just order new ones and put the circuit board from the old one in the new one so my automations remain the same. The motor inside looks very cheap and generic and is almost identical to [google:1pc Motor Part For Neato D2 D3 D4 D5 D6 D7 Vacuum Cleaner Robot Repair Cleaning Accessories] except for a litte white cog on front but alas I cannot find the exact item anywhere.
Nice way to make sure, that the TRV really sits tight on the valve
Would be nice to find a replacement. Remember that WD40 is more of a cleaner than a lubricant. Try some oil instead (IMHO i do not think, that there is enough friction here to slow down the motor)
