Tuya unsupported device
we installed this meter to see how full our water tank is. Unfortunately the Tuya integration rejects it as unsupported. How to access the data anyway?
This is the result of the diagnostic:
Thanks for any help!
Joachim
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2023.12.1",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.11.6",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Africa/Johannesburg",
    "os_name": "Linux",
    "os_version": "6.1.63-haos",
    "supervisor": "2023.11.6",
    "host_os": "Home Assistant OS 11.2",
    "docker_version": "24.0.7",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "solarman": {
      "version": "1.0.0",
      "requirements": [
        "pyyaml",
        "pysolarmanv5"
    "hacs": {
      "version": "1.33.0",
      "requirements": [
        "aiogithubapi>=22.10.1"
  "integration_manifest": {
    "domain": "tuya",
    "name": "Tuya",
    "codeowners": [
      "@Tuya",
      "@zlinoliver",
      "@frenck"
    "config_flow": true,
    "dependencies": [
      "ffmpeg"
    "dhcp": [
        "macaddress": "105A17*"
        "macaddress": "10D561*"
        "macaddress": "1869D8*"
        "macaddress": "381F8D*"
        "macaddress": "508A06*"
        "macaddress": "68572D*"
        "macaddress": "708976*"
        "macaddress": "7CF666*"
        "macaddress": "84E342*"
        "macaddress": "D4A651*"
        "macaddress": "D81F12*"
    "documentation": "https://www.home-assistant.io/integrations/tuya",
    "integration_type": "hub",
    "iot_class": "cloud_push",
    "loggers": [
      "tuya_iot"
    "requirements": [
      "tuya-iot-py-sdk==0.6.6"
    "is_built_in": true
  "data": {
    "endpoint": "https://openapi.tuyaeu.com",
    "auth_type": 0,
    "country_code": "27",
    "app_type": "smartlife",
    "mqtt_connected": true,
    "disabled_by": null,
    "disabled_polling": false,
    "name": "Tank A Level",
    "model": "EPT_Ultrasonic level sensor",
    "category": "ywcgq",
    "product_id": "wtzwyhkev3b4ubns",
    "product_name": "Tank A Level",
    "online": true,
    "sub": false,
    "time_zone": "+02:00",
    "active_time": "2023-12-11T07:20:04+00:00",
    "create_time": "2023-12-11T07:20:04+00:00",
    "update_time": "2023-12-13T10:35:49+00:00",
    "function": {
      "max_set": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
      "mini_set": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
      "installation_height": {
        "type": "Integer",
        "value": {
          "unit": "m",
          "min": 200,
          "max": 2500,
          "scale": 3,
          "step": 1
      "liquid_depth_max": {
        "type": "Integer",
        "value": {
          "unit": "m",
          "min": 100,
          "max": 2400,
          "scale": 3,
          "step": 1
    "status_range": {
      "liquid_state": {
        "type": "Enum",
        "value": {
          "range": [
            "normal",
            "lower_alarm",
            "upper_alarm"
      "liquid_depth": {
        "type": "Integer",
        "value": {
          "unit": "m",
          "min": 0,
          "max": 10000,
          "scale": 2,
          "step": 1
      "max_set": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
      "mini_set": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
        "type": "Integer",
        "value": {
          "unit": "m",
          "min": 200,
          "max": 2500,
          "scale": 3,
          "step": 1
        "type": "Integer",
        "value": {
          "unit": "m",
          "min": 100,
          "max": 2400,
          "scale": 3,
          "step": 1
      "liquid_level_percent": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
    "status": {
      "liquid_state": "normal",
      "liquid_depth": 178,
      "max_set": 100,
      "mini_set": 20,
      "installation_height": 2001,
      "liquid_depth_max": 145,
      "liquid_level_percent": 99
    "home_assistant": {
      "name_by_user": null,
      "disabled": false,
      "entities": []
I just ordered this device too (Zigbee version) and I’d love to see it working/supported in HA.
