Tuya water level sensor is not supported.
Would it be possible for you to share the device with me so that I can implement it in my custom integration (GitHub - azerty9971/xtend_tuya: eXtend Tuya's integration).
From your SmartLife/Tuya app, share the device with:
Smartlife: gg-106053160716494114782
Tuya: [email protected]
This way I should be able to get the necessary diagnostic information I need to implement it fully…
Thanks in advance,
Azerty
Done in Tuya app
Nice ![]()
Have a nice day,
Azerty
The latest version of extended tuya (GitHub - azerty9971/xtend_tuya: eXtend Tuya's integration) now correctly detects your device :).
Please test it and let me know if anything is missing/incorrect.
Have a nice day,
Azerty
Thank you for supporting the sensor.
Unfortunately it only gets the data once on loading/reloading the integration. There are no value updates recognized.
Values during rain last night in Tuya app
Values in Home-Assistant. Today in the morning I reloaded the integration.
I think I know why this is happening, I’ll make the code adjustment and keep you posted ![]()
Have a nice day,
Azerty
The latest release should fix your issue.
Don’t hesitate to update and let me know if everything works as expected :).
Have a nice evening,
Azerty
I bought the same from Amazon to measure the level of oil tank.
I have a lot Tuya components integrated via Zigbee2mgtt.
For this ultrasonic sensor I installed Tuya app and your repository xtendtuya.
But unfortunately I do not get the entitity for the ultrasonic sensor.
Is it needed to install local Tuya repository as well?
In smartlive app I did not activate cloud up to now
Thank you
Can you open an issue there Issues · azerty9971/xtend_tuya · GitHub and provide the diagnostic file for your device?
Also, is it the water level sensor that is not working or the ultrasonic one? (are they the same?)
Azerty
For me, only 4 entities from the system settings pop up. But “liquid_depth” and “liquid_level_percent” are not there. Would it be possible to add these entities there?
“liquid_state”: “normal”,
“liquid_depth”: 107,
“max_set”: 100,
“mini_set”: 0,
“upper_switch”: true,
“installation_height”: 2780,
“liquid_depth_max”: 980,
“liquid_level_percent”: 59
