Tuya WIFI remote control, which one?
I’ve 5 LED controllers installed in my house, they are of the RexTech brand, model: WiFi&BT (DWAB-WFCT). These are rebranded Tuya devices. I can control the 5 Tuya LED controllers from Home Assistant, that is all working.
Now I want to also add a manual button/controller so that when entering the room I can use the button manually to switch on/off the LED strips. Any suggestions which Tuya WiFi controller I need to buy?
Of course, besides the manual controller/switch, controlling the LED strips from Home Assistant should continue to stay working!
Hello Rene,
Any buttons that work in homeassistant should be able to control lights that HA can already control.
Don’t limit yourself.
Also wifi and batteries are not a good mix.
Agreed, thanks. I’ve used a Z-wave Fibaro switch, no lights connected, when the button is being bushed I enable to led strips through an automation and visa versa.
