Tuya WR3 Smart Siren
I’ve been able to flash the Tuya WR3 module using LibreTiny. I’ll post the .yaml to make the siren and leds work.
esphome:
  friendly_name: alarm
rtl87xx:
  board: wr3
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid:xxx
  password: xxx
switch:
  - platform: restart
  - platform: gpio
    pin: PA05
    - platform: wifi_signal
output:
  - platform: libretiny_pwm
    pin: PA12
    frequency: 2600 Hz
light:
  - platform: monochromatic
    output: pwm_output
button:
  on_press:
  - script.execute: buzzer_five
script:
- id: buzzer_five # Use the same buzzer name you have given above.
  then:
    - repeat:
          count: 10
          then:
             - light.turn_on: Sirene
            - switch.turn_on: Lichtje
            - delay: 500ms
            - light.turn_off: Sirene
            - switch.turn_off: Lichtje
            - delay: 1000ms
Thnx for posting this, exactly what I was searching for👍
Do you have some more details how to flash the WR3 Smart Siren?
https://docs.libretiny.eu/boards/wr3/
There’s the information you need.
After a lot of attemps I’ve been able to flash the wr3 chip with esphome. It was difficult for me to place the chip in download mode. Anyway thanks a lot for your esphome config.
I’ve added one of the buttons (PairOnOff) to the esphome config:
binary_sensor:
  - platform: gpio
    pin:
      number: PA15
      inverted: true
      mode:
        input: true
I’m in the same boat :rofl:. Found the siren while looking for something else, thought it would be a 5 min job with a CP2102 but can’t get it into download mode.
And yes, this is also done.
  • connect CEN to GND
  • connect TX2 to GND
  • release CEN from GND
  • release TX2 from GND
This is what I get:
I’m a bit rusty, so can anyone point me to the right direction?
EDIT:
Spoke too soon. The weird part is, that I only reconncted TXD to GND and didn’t use CEN at all now. Suddenly flashing worked…Weird.
All is working well! Thanks @rudy12767 for sharing the YAML file and @dinant for the addition!
