Tuya Zigbee motion sensor stays on detected
I have a tuya zigbee motion sensor via Zigbee2MQTT which always worked perfectly. Since the last update of HAOS the device stays on ‘detected’ and keeps detecting motion all the time when no one is home. I only goes between ‘became unavailable’ and ‘detected occupancy’ and never to ‘clear’ as before
In the settings in the mqqt broker there isn’t much I can set only values in
Retention
QoS
Debounce
Filtered attributes from cache
Filtered optimistic attributes
Optimistic
Throttle
But I have no idea what to set there and if this solves the problem. As I said, it dod work flawlessly before
Ignore debounce
My Tuya Zigbee motion sensors do this when their batteries are running low (under 35%), but this doesn’t seem to be the only cause.
