Hi, I’ve got 4 the same sensor, 3 od them working fine, 1 which is closest to Zigbee hub is connecting fine but shows 0 for temperature and 0 for humidity.
All others work fine, any idea? I have tried resetting multiple times, changing batteries and rooms but nothing helped.
I have home assistant OS on miniPC with Zigbee stick.
Paste the model number (`TZ3000_…) of the working ones.
If it’s the same, then you will probably need to re-pair your non-working sensor. IF it’s different, then you will probably need a zigbee quirk for it.
Unfortunately, this is pretty common. In my experience, Tuya’s Zigbee devices can be very hit-or-miss. I would estimate, conservatively, that 1 in 4 battery-powered devices and 1 in 6 mains-powered devices are defective in some way.
