Hi everybody,
I purchased a round Tuya Zigbee thermometer with display.
I use a Skyconnect with ZHA, the thermometer connects without problems and reports the initial temperature and air pressure. Unfortunately it never updates those values and after a few hours only reports 0 degrees and air pressure.
I noticed that there exists a quirk for the TS0201, unfortunately not for my specific model.
The zigbee signature is
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0402",
"input_clusters": [
"0x0000",
"0x0001",
"0x0004",
"0x0402",
"0x0405",
"0xe002"
"output_clusters": [
"0x0004",
"0x000a",
"0x0019"
"manufacturer": "_TZ3210_qkj7rujp",
"model": "TS0201",
"class": "zigpy.device.Device"
In the quirk I found the class class MoesTemperatureHumidtySensorWithScreen(CustomDevice): """Moes temperature and humidity sensor with screen.""
and figured that that might best fit my device. I tried editing the quirk with my zigbee signature, resulting in
"""Tuya TS201 temperature, humidity and optional illumination sensors."""
from zigpy.profiles import zha
from zigpy.profiles.zha import DeviceType
from zigpy.quirks import CustomCluster, CustomDevice
import zigpy.types as t
from zigpy.zcl.clusters.general import Basic, Identify, Ota, PowerConfiguration, Time
from zigpy.zcl.clusters.measurement import (
IlluminanceMeasurement,
RelativeHumidity,
TemperatureMeasurement,
from zigpy.zdo.types import NodeDescriptor
from zhaquirks.const import (
DEVICE_TYPE,
ENDPOINTS,
INPUT_CLUSTERS,
MODELS_INFO,
NODE_DESCRIPTOR,
OUTPUT_CLUSTERS,
PROFILE_ID,
class ValueAlarm(t.enum8):
"""Temperature and humidity alarm values."""
ALARM_OFF = 0x02
MAX_ALARM_ON = 0x01
MIN_ALARM_ON = 0x00
class TuyaTemperatureHumidityAlarmCluster(CustomCluster):
"""Tuya temperature and humidity alarm cluster (0xE002)."""
name = "Tuya Temperature and Humidity Alarm Cluster"
cluster_id = 0xE002
attributes = {
# Alarm settings
0xD00A: ("alarm_temperature_max", t.uint16_t, True),
0xD00B: ("alarm_temperature_min", t.uint16_t, True),
0xD00C: ("alarm_humidity_max", t.uint16_t, True),
0xD00E: ("alarm_humidity_min", t.uint16_t, True),
# Alarm information
0xD00F: ("alarm_humidity", ValueAlarm, True),
0xD006: ("temperature_humidity", ValueAlarm, True),
# Unknown
0xD010: ("unknown", t.uint8_t, True),
class RelativeHumidityX10(CustomCluster, RelativeHumidity):
"""Handles invalid humidity values."""
def _update_attribute(self, attrid, value):
# x10 factor in measured_value`(attrid=0)
if attrid == 0:
value = value * 10
super()._update_attribute(attrid, value)
"""Moes temperature and humidity sensor with screen."""
signature = {
# <SimpleDescriptor endpoint=1, profile=260, device_type="0x0402"
# input_clusters=["0x0000", "0x0001", "0x0004", "0x0402", "0x0405", "0xe002"]
# output_clusters=["0x0004", "0x000a", "0x0019"]>
MODELS_INFO: [("_TZ3210_qkj7rujp", "TS0201")],
ENDPOINTS: {
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: DeviceType.TEMPERATURE_SENSOR,
INPUT_CLUSTERS: [
Basic.cluster_id,
PowerConfiguration.cluster_id,
Identify.cluster_id,
TemperatureMeasurement.cluster_id,
RelativeHumidity.cluster_id,
TuyaTemperatureHumidityAlarmCluster.cluster_id,
OUTPUT_CLUSTERS: [
Time.cluster_id,
Ota.cluster_id,
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
RelativeHumidityX10,
TuyaTemperatureHumidityAlarmCluster,
OUTPUT_CLUSTERS: [
Time.cluster_id,
Ota.cluster_id,
However, after adding the quirk folder to my configuration.yaml, restarting HA, restarting ZHA an even re-adding the device a couple of times it still won’t apply the quirk.
Where’s the error?
Did I mess up the quirk?
Do I need to rename it to something special? So far it’s still named ts0201.py like the standard one.
Thank you so much in advance.
