TuyaMCU: Datapoints are received and updated but no sensors on GUI
I have 6-in-1 Tuya air box with PM2.5, temperature, humidity and so on.
It has T1-3S with TuyaMCU. I successfully flashed ESPHome onto T1-3S and I can see datapoint updates via logs.
However, sensors does not show up on neither GUI nor HA.
Here is the yaml.
uart:
  rx_pin: RX1
  tx_pin: TX1
  baud_rate: 9600
  rx_buffer_size: 512
  debug:
    direction: BOTH
    sequence:
      - lambda: UARTDebug::log_hex(direction, bytes, ':');
tuya:
  uart_id: uart_bus
  time_id: ntp_time
  status_pin:
    number: P26
  - platform: tuya
    sensor_datapoint: 18
    unit_of_measurement: "°C"
    icon: mdi:thermometer
    device_class: temperature
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
  - platform: tuya
    sensor_datapoint: 19
    unit_of_measurement: "%"
    icon: mdi:water-percent
    device_class: humidity
    filters:
      - multiply: 0.1
  - platform: tuya
    sensor_datapoint: 2
    unit_of_measurement: "µg/m³"
    icon: "mdi:blur"
    device_class: aqi
    accuracy_decimals: 0
  - platform: tuya
    sensor_datapoint: 20
    unit_of_measurement: "mg/m³"
    device_class: "volatile_organic_compounds"
    state_class: "measurement"
    filters:
      - multiply: 0.01
  - platform: tuya
    sensor_datapoint: 21
    device_class: volatile_organic_compounds_parts
    filters:
      - multiply: 0.1
  - platform: tuya
    sensor_datapoint: 22
    unit_of_measurement: "ppm"
    device_class: "carbon_dioxide"
Here is the log.
[01:58:50.641][I][app:164]: ESPHome version 2026.10.2 compiled on 2026-11-12 23:40:02 +0900
[01:58:50.641][C][logger:218]: Logger:
[01:58:50.641][C][logger:218]:   Max Level: DEBUG
[01:58:50.641][C][logger:218]:   Initial Level: DEBUG
[01:58:50.641][C][logger:225]:   Log Baud Rate: 0
[01:58:50.641][C][logger:225]:   Hardware UART: DEFAULT
[01:58:50.641][C][logger:234]:   Task Log Buffer Size: 768 bytes
[01:58:50.671][C][uart:132]: UART Bus:
[01:58:50.671][C][uart:132]:   Type: hardware
[01:58:50.679][C][uart:137]:   Port number: 1
[01:58:50.679][C][uart:131]:   TX Pin: 11
[01:58:50.679][C][uart:131]:   RX Pin: 10
[01:58:50.686][C][uart:142]:   RX Buffer Size: 512
[01:58:50.686][C][uart:144]:   Baud Rate: 9600 baud
[01:58:50.686][C][uart:144]:   Data Bits: 8
[01:58:50.686][C][uart:144]:   Parity: NONE
[01:58:50.686][C][uart:144]:   Stop bits: 1
[01:58:50.731][C][restart.button:014]: Restart Button 'Restart'
[01:58:50.731][C][restart.button:157]:   Icon: 'mdi:restart'
[01:58:50.749][C][captive_portal:162]: Captive Portal:
[01:58:50.770][C][wifi:1688]: WiFi:
[01:58:50.770][C][wifi:1688]:   Local MAC: 30:48:7D:A5:D5:BD
[01:58:50.770][C][wifi:1688]:   Connected: YES
[01:58:50.776][C][wifi:1392]:   IP Address: 192.168.0.156
[01:58:50.783][C][wifi:1403]:   SSID: 'XXXXXXX'
[01:58:50.783][C][wifi:1403]:   BSSID: E4:67:1E:94:67:E2
[01:58:50.783][C][wifi:1403]:   Hostname: 'tuya-air-box'
[01:58:50.783][C][wifi:1403]:   Signal strength: -54 dB ▂▄▆█
[01:58:50.783][C][wifi:1403]:   Channel: 1
[01:58:50.783][C][wifi:1403]:   Subnet: 255.255.255.0
[01:58:50.783][C][wifi:1403]:   Gateway: 192.168.0.1
[01:58:50.783][C][wifi:1403]:   DNS1: 192.168.0.1
[01:58:50.783][C][wifi:1403]:   DNS2: 192.168.0.1
[01:58:50.806][C][web_server:430]: Web Server:
[01:58:50.806][C][web_server:430]:   Address: tuya-air-box.local:80
[01:58:50.829][C][sntp:058]: SNTP Time:
[01:58:50.839][C][sntp:061]:   Server 0: '0.kr.pool.ntp.org'
[01:58:50.839][C][time:051]: Timezone: UTC+9:00
[01:58:50.839][C][time:055]: Current time: 2026-11-17 01:58:50
[01:58:50.859][C][esphome.ota:129]: Over-The-Air updates:
[01:58:50.859][C][esphome.ota:129]:   Address: tuya-air-box.local:8892
[01:58:50.859][C][esphome.ota:129]:   Version: 2
[01:58:50.874][C][safe_mode:058]: Safe Mode:
[01:58:50.874][C][safe_mode:058]:   Successful after: 60s
[01:58:50.874][C][safe_mode:058]:   Invoke after: 10 attempts
[01:58:50.874][C][safe_mode:058]:   Duration: 300s
[01:58:50.901][C][web_server.ota:256]: Web Server OTA
[01:58:50.916][C][api:368]: Server:
[01:58:50.916][C][api:368]:   Address: tuya-air-box.local:6053
[01:58:50.916][C][api:368]:   Listen backlog: 4
[01:58:50.916][C][api:368]:   Max connections: 5
[01:58:50.922][C][api:380]:   Noise encryption: NO
[01:58:50.940][C][mdns:324]: mDNS:
[01:58:50.940][C][mdns:324]:   Hostname: tuya-air-box
[01:58:50.959][C][libretiny:015]: LibreTiny:
[01:58:50.959][C][libretiny:015]:   Version: v1.13.0+sha.6514b26 on t1-3s, compiled at Nov 16 2026 22:36:03, GCC 10.3.1 (-O1)
[01:58:50.959][C][libretiny:015]:   Loglevel: 3
[01:58:50.966][C][libretiny:021]:   Optimization: -Os, SDK: -O1
[01:58:50.987][C][debug:017]: Debug component:
[01:58:50.995][D][debug:031]: ESPHome version 2026.10.2
[01:58:50.995][D][debug:035]: Free Heap Size: 138832 bytes
[01:58:50.995][D][debug:044]: Uptime: 0d 00h 13m 54s
[01:58:51.004][D][debug:028]: LibreTiny debug info:
[01:58:51.004][D][debug:028]:   Version: 1.13.0+sha.6514b26
[01:58:51.004][D][debug:028]:   Chip: BK7238 (1538) @ 120 MHz
[01:58:51.004][D][debug:028]:   Chip ID: 0xBDD5A5
[01:58:51.004][D][debug:028]:   Board: t1-3s
[01:58:51.004][D][debug:028]:   Flash: 2048 KiB
[01:58:51.004][D][debug:028]:   RAM: 256 KiB
[01:58:51.004][D][debug:028]:   Reset Reason: SW Reboot
[01:58:51.022][C][tuya:062]: Tuya:
[01:58:51.038][C][tuya:081]:   Datapoint 20: int value (value: 7)
[01:58:51.039][C][tuya:081]:   Datapoint 21: int value (value: 17)
[01:58:51.039][C][tuya:081]:   Datapoint 22: int value (value: 428)
[01:58:51.044][C][tuya:081]:   Datapoint 2: int value (value: 8)
[01:58:51.044][C][tuya:081]:   Datapoint 18: int value (value: 260)
[01:58:51.044][C][tuya:081]:   Datapoint 19: int value (value: 423)
[01:58:51.044][C][tuya:093]:   GPIO Configuration: status: pin 26, reset: pin 23
[01:58:51.064][C][tuya:097]:   Product: '{"p":"ugjbnqj2mffaexp5","v":"1.0.0","m":0}'
[01:58:51.089][S][text_sensor]: 'Reset Reason' >> 'SW Reboot'
[01:58:54.363][D][tuya:415]: Datapoint 18 update to 261
[01:58:54.384][D][tuya:415]: Datapoint 19 update to 419
[01:58:54.497][D][uart_debug:113]: <<< 55:AA:03:07:00:08:12:02:00:04:00:00:01:05:2F:55:AA:03:07:00:08:13:02:00:04:00:00:01:A3:CE
[01:59:01.633][D][uart_debug:113]: >>> 55:AA:00:00:00:00:FF
[01:59:16.628][D][uart_debug:113]: >>> 55:AA:00:00:00:00:FF
[01:59:24.525][D][tuya:415]: Datapoint 18 update to 263
[01:59:24.546][D][tuya:415]: Datapoint 19 update to 418
[01:59:24.659][D][uart_debug:113]: <<< 55:AA:03:07:00:08:12:02:00:04:00:00:01:07:31:55:AA:03:07:00:08:13:02:00:04:00:00:01:A2:CD
[01:59:31.544][D][uart_debug:113]: >>> 55:AA:00:00:00:00:FF
[01:59:31.668][D][uart_debug:113]: <<< 55:AA:03:00:00:01:01:04
[01:59:32.063][D][tuya:415]: Datapoint 18 update to 262
[01:59:32.082][D][tuya:415]: Datapoint 19 update to 418
[01:59:32.196][D][uart_debug:113]: <<< 55:AA:03:07:00:08:12:02:00:04:00:00:01:06:30:55:AA:03:07:00:08:13:02:00:04:00:00:01:A2:CD
[01:59:39.607][D][tuya:415]: Datapoint 18 update to 262
[01:59:39.628][D][tuya:415]: Datapoint 19 update to 423
[01:59:39.746][D][uart_debug:113]: <<< 55:AA:03:07:00:08:12:02:00:04:00:00:01:06:30:55:AA:03:07:00:08:13:02:00:04:00:00:01:A7:D2
[01:59:46.635][D][uart_debug:113]: >>> 55:AA:00:00:00:00:FF
[01:59:52.057][D][tuya:415]: Datapoint 20 update to 2
[01:59:52.095][D][tuya:415]: Datapoint 21 update to 6
[01:59:52.095][D][tuya:415]: Datapoint 22 update to 413
[01:59:52.095][D][tuya:415]: Datapoint 2 update to 8
[01:59:52.209][D][uart_debug:113]: <<< 55:AA:03:07:00:08:14:02:00:04:00:00:00:02:2D:55:AA:03:07:00:08:15:02:00:04:00:00:00:06:32:55:AA:03:07:00:08:16:02:00:04:00:00:01:9D:CB:55:AA:03:07:00:08:02:02:00:04:00:00:00:08:21
[01:59:58.901][D][sntp:099]: Synchronized time: 2026-11-17 01:59:58
[02:00:00.602][D][tuya:415]: Datapoint 20 update to 2
[02:00:00.623][D][tuya:415]: Datapoint 21 update to 8
[02:00:00.642][D][tuya:415]: Datapoint 22 update to 414
[02:00:00.647][D][tuya:415]: Datapoint 2 update to 5
[02:00:00.743][D][uart_debug:113]: <<< 55:AA:03:07:00:08:14:02:00:04:00:00:00:02:2D:55:AA:03:07:00:08:15:02:00:04:00:00:00:08:34:55:AA:03:07:00:08:16:02:00:04:00:00:01:9E:CC:55:AA:03:07:00:08:02:02:00:04:00:00:00:05:1E
[02:00:01.555][D][uart_debug:113]: >>> 55:AA:00:00:00:00:FF
[02:00:01.671][D][uart_debug:113]: <<< 55:AA:03:00:00:01:01:04
[02:00:08.837][D][wifi:2598]: Roam scan (-54 dBm, attempt 3/3)
[02:00:10.233][D][tuya:415]: Datapoint 20 update to 4
[02:00:10.233][D][tuya:415]: Datapoint 21 update to 12
[02:00:10.233][D][tuya:415]: Datapoint 22 update to 416
[02:00:10.233][D][tuya:415]: Datapoint 2 update to 8
[02:00:10.233][D][uart_debug:113]: <<< 55:AA:03:07:00:08:14:02:00:04:00:00:00:04:2F:55:AA:03:07:00:08:15:02:00:04:00:00:00:0C:38:55:AA:03:07:00:08:16:02:00:04:00:00:01:A0:CE:55:AA:03:07:00:08:02:02:00:04:00:00:00:08:21
[02:00:10.233][D][tuya:415]: Datapoint 18 update to 261
[02:00:10.242][D][tuya:415]: Datapoint 19 update to 424
[02:00:10.242][D][uart_debug:113]: <<< 55:AA:03:07:00:08:12:02:00:04:00:00:01:05:2F:55:AA:03:07:00:08:13:02:00:04:00:00:01:A8:D3
As far as I know, once you identify datapoints and define sensors pointing to said datapoints (for exmaple, datapoint 18 to temperature), respectively, the values automatically show up on the GUI.
What am I doing wrong here?
Try how it goes if you remove id from tuya: or alternatively add tuya_id: tuya_mcu on all your sensors.
I have a fan contoller and this worked. No sensors but might point you in the right direction.
uart:
  rx_pin: RX1
  tx_pin: TX1
  baud_rate: 9600
tuya:
#Results;
#Datapoint 1: switch (value: OFF) Fan on/off. Off still shows 41Vac on terminals?
#Datapoint 15: switch (value: OFF) Light on/off
#Datapoint 101: enum (value: 2) Panel light control. Touch buttons still work for all settings
#                               0=no lights 1=red lights for whatever is on 2=all lights on at current status red active/blue inactive.
#Datapoint 102: enum (value: 0) Fan speed. 0=140V 1=180V 2=240V
#Datapoint 103: enum (value: 0) ?? Does nothing.
#Product: '{"p":"suqauqtajcualhw5","v":"1.0.0","m":2}'
switch:
  - platform: "tuya"
    switch_datapoint: 15
  - platform: "tuya"
    switch_datapoint: 1
select:
  - platform: "tuya"
    tuya_id: tuyamcu
    name: "Speed selection"
    enum_datapoint: 102
    options:
      0: Low
      1: Med
      2: High
  - platform: "tuya"
    tuya_id: tuyamcu
    name: "Light selection"
    enum_datapoint: 101
    options:
      0: 'Off'
      1: Active
      2: All
number:
  - platform: "tuya"
    number_datapoint: 101
    min_value: 0
    max_value: 2
    step: 1
  - platform: "tuya"
    number_datapoint: 102
    min_value: 0
    max_value: 2
    step: 1
    on_value:
      then:
        - switch.turn_on:
Neither works.
I have no idea what is wrong with yaml…
Thanks anyway.
Thank you for your reply.
The datapoints are all read-only..
I have no idea whether this problem is caused by ESPHome (LibreTiny: BK7238) or Tuya MCU.
I have a completely different Tuya device with CBU and two sensors and it worked as intended once it was flashed with ESPHome..
I should try replacing T1-3S with ESP32 and see how it goes.
Doesn’t look like problem with tuya since you get your points on logs. Some stupid thing preventing sensors to work.
Try absolute minimum.
uart:
  rx_pin: RX1
  tx_pin: TX1
  baud_rate: 9600
tuya:
  - platform: tuya
Another thing you could test is if on_datapoint_update automation works or not.
Replacing T1-3S with ESP32C3-12 solved everything.
Sensors correctly show up in the WebUI and HA.
I guess LibreTiny cannot handle some Beken chips correctly.
