Is it possible to change channels on or set the volume webos tv.
I know its possible to do source inputs as I have IFTTT setup so I can say switch to plex and it will change to the plex app.
On the panel in HA there are 3 buttons for the volume (mute,up,down). How would I access these in IFTTT with the Google Assistant.
I also want to be able to say “put channel 1 on” or use the channel name “change to BBC2” and have the TV change to that channel.
Im using this - https://home-assistant.io/components/media_player.webostv/
