TV LG - youtube play
although is a small contribution, hope you might find it useful .
play most recent youtube on a channel , directly in LG TV
First , use media extractor to scrape youtube latest video ID
  - platform: scrape
    resource: 'https://www.youtube.com/feeds/videos.xml?channel_id=UCFUyy6LM16KiI-VdA6pMO0Q'
    value_template: '{{ value }}'
    select: yt\:videoid
then, create a script to play it to your LG TV
futurist:
  alias: futurist
  sequence:
    - service: webostv.command
      data_template:
        entity_id: media_player.tv_lg_2
        command: "system.launcher/launch"
        payload:
          contentId: "{{ states('sensor.yt_futurist') }}"
I’m using a Lovelace Glance to execute the script
entities:
  - entity: script.futurist
    image: /local/youtube.png
    show_state: false
    tap_action:
      action: toggle
type: glance
Enjoy :slight_smile:
Very nice found!
For future reference, I didn’t don’t use media extractor but scrape, to scrape the last video ID from that XML url.
Your yaml is spot on though :ok_hand:
https://www.home-assistant.io/integrations/scrape/ :point_left: this sensor is the scrape sensor.
Your option is designed for specific video content. But it would be much more interesting when the search for content on request is launched. How, for example, to launch a youtube channel search for a query on a topic of interest?
For understanding, I will give examples of how the search strings on youtube look like
This is what the youtube search bar looks like
https://www.youtube.com/results?search_query=
This is how the youtube search bar looks with an indication of the search topic, for example, “documentaries about space”
www.youtube.com/results?search_query=documentaries+about+space
This is how the youtube search bar looks using variables, so that when a trigger is triggered, this search is launched
https://www.youtube.com/results?search_query={{ trigger.event.data.book|replace(" ", "+") }}
Now let’s get to the point
We have a smart speaker with a voice assistant Alice, an analogue of your Alexa, when I ask you to find something, for example: “Alice, find documentaries about space,” then an event appears in the Home Assistant that looks like this
    "event_type": "yandex_intent",
    "data": {
        "text": "Alice find documentaries about space",
        "command": "Alice find documentaries about space",
        "intent": "YANDEX.BOOK.SEARCH",
        "book": "documentaries about space"
    "origin": "LOCAL",
    "time_fired": "2021-10-14T14:20:02.517357+00:00",
    "context": {
        "id": "e802961a0196af60036511eb117d398f",
        "parent_id": null,
        "user_id": null
Then, thanks to these events, you can create automation, where the trigger is an event
platform: event
event_type: yandex_intent
event_data:
  intent: YANDEX.BOOK.SEARCH
and in action it is used
{{ trigger.event.data.book|replace(" ", “+”) }}
As a result, we can combine and run a search on the topic of interest to us. There are two options below, but only one option works. This, as I understand it, is due to the feature of webos integration
This option is working, but it opens in the browser and does not work in the youtube app
  entity_id: media_player.tv_bedroom
  command: system.launcher/open
  payload:
    target: >-
This option is not working, it gives the error “This video is not available”
  command: system.launcher/launch
  payload:
    contentId: https://www.youtube.com/results?search_query={{ searsh | replace(" ", "+") }}
Текст на русском (Text in Russian)
Ваш вариант рассчитан для конкретного видеоконтента. Но намного интереснее было бы, когда запускается поиск контента по запросу. Как к примеру запустить на youtube поиск каналов по запросу на интересующую тематику?
Для понимания приведу примеры как выглядят строки поиска на youtube
Так выглядит поисковая строка youtube
Так выглядит поисковая строка youtube с указанием темы поиска, например “документальные фильмы про космос”
Так выглядит поисковая строка youtube с использованием переменных, чтобы при срабатывании триггера этот поиск запускался
Теперь перейдем к сути
У нас есть умная колонка с голосовым помощником Алиса, аналог вашей Алексы, когда я прошу найти что-то, например: “Алиса, найди документальные фильмы про космос”, то в Home Assistant появляется событие, которое выглядит вот таким образом
    "data": {
        "text": "алиса найди документальные фильмы про космос",
        "command": "алиса найди документальные фильмы про космос",
        "book": "документальные фильмы про космос"
    "origin": "LOCAL",
    "context": {
        "parent_id": null,
        "user_id": null
То благодаря этим событиям можно создать автоматизацию, где триггером выступает событие
platform: event
event_data:
а в действии используется
В итоге можем объединить и запускать поиск по интересующейся нас тематики. Ниже представлены два варианта, но работает только один вариант. Это, как я понял, что связано с особенностью интеграции webos
Этот вариант рабочий, но он открывается в браузере и не работает в приложении youtube
  payload:
    target: >-
Этот вариант не рабочий, выдает ошибку “Это видео не доступно”
  payload:
