Tv sony trinitron, broadlink and base 64 codes for remote control
Hi folks!
I’ve spent more than 8 hours on this challenge, I hope can help someone in the future.
Here below you can find all the key mapping for Sony Trinitron remotes (e.g. RM-833, RM-831, RM-837…) and is also included a sequence to enter the service mode (for the Sony KV-X2901A in specific).
All the best.
#POWER
sony_remote_power:
    sequence:
       - action: remote.send_command
            entity_id: remote.telecomando_universale
            command: b64:JgEcAFIQKREWESkRFhEpERYRFhEpERYRFhEWERUAA0YNBQAAAAAAAAAAAAA=
#KEYS NUMBERS
sony_remote_key_1:
    sequence:
            command: b64:JgEcAFIQFhEWERYRFhEWERYRFhEpERYRFhEWERUAA4ENBQAAAAAAAAAAAAA=
sony_remote_key_2:
    sequence:
            command: b64:JgEcAFIQKREWERYRFhEWERYRFhEpERYRFhEWERUAA20NBQAAAAAAAAAAAAA=
sony_remote_key_3:
    sequence:
            command: b64:JgEcAFIQFhEpERYRFhEWERYRFhEpERYRFhEWERUAA20NBQAAAAAAAAAAAAA=
sony_remote_key_4:
    sequence:
            command: b64:JgEcAFIQKREpERYRFhEWERYRFhEpERYRFhEWERUAA1oNBQAAAAAAAAAAAAA=
sony_remote_key_5:
    sequence:
            command: b64:JgEcAE8TExMTEycTExMTExMTExMnExMTExMTExMAA3kNBQAAAAAAAAAAAAA=
sony_remote_key_6:
    sequence:
            command: b64:JgEcAE4TJxMTEycTExMTExMTExMnExMTExMTExMAA1wNBQAAAAAAAAAAAAA=
sony_remote_key_7:
    sequence:
            command: b64:JgEcAFIQFhEpESkRFhEWERYRFhEpERYRFhEWERUAA1oNBQAAAAAAAAAAAAA=
sony_remote_key_8:
    sequence:
            command: b64:JgEcAFIQKREpESkRFhEWERYRFhEpERYRFhEWERUAA0YNBQAAAAAAAAAAAAA=
sony_remote_key_9:
    sequence:
            command: b64:JgEcAFIQFhEWERYRKREWERYRFhEpERYRFhEWERUAA20NBQAAAAAAAAAAAAA=
sony_remote_key_0:
    sequence:
            command: b64:JgEcAFIQKREWERYRKREWERYRFhEpERYRFhEWERUAA1oNBQAAAAAAAAAAAAA=
sony_remote_key_102nd:
    sequence:
            command: b64:JgEcAFIQKREWESkRKREpERYRFhEpERYRFhEWERUAAzINBQAAAAAAAAAAAAA=
sony_remote_key_c:
    sequence:
            command: b64:JgEcAFIQFhEpESkRKREWERYRFhEpERYRFhEWERUAA0YNBQAAAAAAAAAAAAA=
#VOLUME SETTING
sony_remote_volume_up:
    sequence:
            command: b64:JgEcAE8TExMnExMTExMnExMTExMnExMTExMTExMAA2cNBQAAAAAAAAAAAAA=
sony_remote_volume_down:
    sequence:
            command: b64:JgEcAE8TJxMnExMTExMnExMTExMnExMTExMTExMAA1QNBQAAAAAAAAAAAAA=
sony_remote_volume_muted:
    sequence:
            command: b64:JgEcAFIQFhEWESkRFhEpERYRFhEpERYRFhEWERUAA1oNBQAAAAAAAAAAAAA=
#CHANNEL SELECTION
sony_remote_channel_up:
    sequence:
            command: b64:JgEcAE8TExMTExMTExMnExMTExMnExMTExMTExMAA3kNBQAAAAAAAAAAAAA=
sony_remote_channel_down:
    sequence:
            command: b64:JgEcAE4TJxMTExMTExMnExMTExMnExMTExMTExMAA2INBQAAAAAAAAAAAAA
#COLORS BUTTONS
sony_remote_red_key:
    sequence:
            command: b64:JgEcAFIQFhEWESkRKREWERYRKREpESkRFhEWERUAAzINBQAAAAAAAAAAAAA=
sony_remote_green_key:
    sequence:
            command: b64:JgEcAFIQKREWESkRKREWERYRKREpESkRFhEWERUAAx8NBQAAAAAAAAAAAAA=
sony_remote_yellow_key:
    sequence:
            command: b64:JgEcAFIQFhEpESkRKREWERYRKREpESkRFhEWERUAAx8NBQAAAAAAAAAAAAA=
sony_remote_blue_key:
    sequence:
            command: b64:JgEcAFIQKREpESkRKREWERYRKREpESkRFhEWERUAAwsNBQAAAAAAAAAAAAA=
sony_remote_white:
    sequence:
            command: b64:JgEcAFIQFhEWERYRKREWERYRKREpESkRFhEWERUAA0YNBQAAAAAAAAAAAAA=
#MENU
sony_remote_menu:
    sequence:
            command: b64:JgEcAFIQFhEWERYRFhEWESkRKREpERYRFhEWERUAA1oNBQAAAAAAAAAAAAA=
sony_remote_up:
    sequence:
            command: b64:JgEcAFIQFhEWESkRFhEpESkRKREpERYRFhEWERUAAzINBQAAAAAAAAAAAAA=
sony_remote_down:
    sequence:
            command: b64:JgEcAFIQKREWESkRFhEpESkRKREpERYRFhEWERUAAx8NBQAAAAAAAAAAAAA=
sony_remote_center:
    sequence:
            command: b64:JgEcAFIQFhEpESkRFhEpERYRFhEpERYRFhEWERUAA0YNBQAAAAAAAAAAAAA=
#OTHER
sony_remote_tv:
    sequence:
            command: b64:JgEcAFIQFhEWERYRKREpESkRFhEpERYRFhEWERUAA0YNBQAAAAAAAAAAAAA=
sony_remote_tv_info:
    sequence:
            command: b64:JgEcAFEQFhApEBYQKRApECkQFhApEBYQFhAWEBYAA3QNBQAAAAAAAAAAAAA=
sony_remote_tv_video:
    sequence:
            command: b64:JgEcAFIQKREWESkRFhEWESkRFhEpERYRFhEWERUAA0YNBQAAAAAAAAAAAAA=
#SERVICE MODE
sony_remote_service_mode:
    sequence:
           command:
           - b64:JgEcAFEQFhApEBYQKRApECkQFhApEBYQFhAWEBYAA3QNBQAAAAAAAAAAAAA=
           - b64:JgEcAE8TExMTEycTExMTExMTExMnExMTExMTExMAA3kNBQAAAAAAAAAAAAA=
           - b64:JgEcAE8TExMnExMTExMnExMTExMnExMTExMTExMAA2cNBQAAAAAAAAAAAAA=
           - b64:JgEcAFIQFhEWERYRKREpESkRFhEpERYRFhEWERUAA0YNBQAAAAAAAAAAAAA=
Here a short guide:
1) Find your remote here https://lirc.sourceforge.net/remotes (e.g. https://lirc.sourceforge.net/remotes/sony/RM-833)
2) Download IrScrutinizer
3) Under the TAB Import, choose LIRC and use the "Load File/Url" button
4) Select the KEY, click the dx mouse button and choose "Scrutinized Selected"
5) Click on "Scrutinize signal" tab
6) Copy the Pronto HEX values
7) Remove any white spaces from the Pronto HEX string
8) Copy it here https://www.jdoodle.com/embed/v0/eBD and click Execute.
9) Copy the result here to tranform HEX in base64 https://tomeko.net/online_tools/hex_to_base64.php?lang=en
10) Copy the result here https://dimagoltsman.github.io/Random-Broadlink-RM-Code-Generator/# (TAB Change Repeats) to introduce some repetition (1 is enough)
11) insert the value into your script.
12) Profit!
