Tv switch and automation
Hi guys! really rookie here. Im trying to create a switch to turn on/off the TV. As Ive an old TV (2012) Ive done it using CEC_HDMI. Ive created a scrip to turn on and another to turn it off and both works correctly. Now I want instead of the script to use the switch in the UI. I`ve created the folowing automation
   - alias: Turn TV off
       platform: state
       entity_id: switch.hdmi_0
       to: 'off'
       service: hdmi_cec.standby
and the configuration file is as follows
hdmi_cec:
  devices:
    TV: 0.0.0.0
The result is that the switch is only showing the TV state but it does not respond to the changes, every time I change the switch.
Any suggestion on what I`m doing wrong?
Thank you in advance!
if you somehow have a way to find out if the TV is on or off, you can use a template switch
Otherwise I’d just create a “dummy” input_boolean to control your TV and add an automation based on the input_boolean as a trigger:
- alias: TV Control
    - platform: state
      entity_id: input_boolean.tv_switch
    - service_template: >
      hdmi_cec.{% if states.input_boolean.tv_switch.state =='on' %}power_on{% else %}standby{% endif %}
