HOME.BOY requires an existing Home Assistant installation on your local network to turn your Apple TV into an ambient dashboard for Home Assistant — a second screen for your home that’s always on, always calm, and built for the living room.
MONITOR
See every room at a glance: temperature, humidity and other sensors, grouped by room, with history sparklines so you can see where things are headed, not just where they are. Turn lights off, adjust fans, and trigger scenes right from the Apple TV remote — no app on your phone required.
FAMILY
A shared calendar and two independent to-do lists (chores, whatever your household needs) pulled straight from Home Assistant, laid out for reading from across the room.
WEATHER
A full-screen animated backdrop — real clouds, rain, stars and a day/night sky — driven by your actual local conditions, plus an hourly and daily forecast strip.
SETUP
Point it at your Home Assistant server (auto-discovery included) with a long-lived access token, and you’re done. No account is needed, no cloud middleman — HOME.BOY talks directly to your own Home Assistant instance.
