TVT Cameras and Port 6036 + HA
At one point or another, someone installed HD-SDI cameras and a DVR in my house. I want to integrate it to HA.
The dvr works great, and is connected to the network, and I can view cameras in NVMS 2.11.
The server port is 6036
There is no RSTP or OnVIF, and when I go to the dvr itself via it’s website, I need to load activex to connect. It will only connect through something called standard, and nmap defines the port as X11?
Only ports open are 25, 80, 6036
Does anyone have any suggestions for specifically a hd-sdi dvr (most dvr’s do not support the dead standard) that will output onvif or rstp? If not does anyone have a work around besides ripping apart all the walls in my house to install a new camera system?
I tried agent dvr and blue iris to no success.
Any help is greatly appreciated!
Do you know the mpeg urls?
Can you find your camera or NVR make and models in this list?
https://www.ispyconnect.com/cameras
I tried that as well, don’t think it outputs mjpeg.
The only information I have is that it runs on “Cross Web Server”. I tried using the ispy link to generate urls but none of them work.
What make and model NVR is it?
So the box itself is unmarked, but what I do know is it is a TVT 10671.0.14.Q17-v1.2-31xx hardware version. Best I can tell it is most similar or is a TVT td-2708xd-p.
any update about this ? I’m in the same situation
