Whi can help me.
I installed twente milieu for pickup garbage data.
But the data is firts year month day
Is ir possible to changw it to day month year?
And one of them is not working look picture
Whi can help me.
I had the same problem and solved it using a template sensor to change it to DD-MM-YYYY although it would be better if it’s solved in twente milieu itself.
sensors:
non_recyclable_waste_pickup_date:
friendly_name: "Non Recyclable"
value_template: '{{ strptime(states.sensor.non_recyclable_waste_pickup.state, "%Y-%m-%d").strftime("%d-%m-%Y") }}'
Ok thanks,
Did al the dates worked for u?
And with youre option is it possible to use own icons local i did?
I have some troubles with the paper collection state, it stays ‘unknown’.
I’ve added some custom pictures to the “config/www/icons” folder and used the following template sensor:
sensors:
entity_picture_template: /local/icons/waste_non_recyclable.png
plastic_waste_pickup_date:
friendly_name: "Plastic"
entity_picture_template: /local/icons/waste_plastic.png
value_template: '{{ strptime(states.sensor.plastic_waste_pickup.state, "%Y-%m-%d").strftime("%d-%m-%Y") }}'
organic_waste_pickup_date:
friendly_name: "Organic"
entity_picture_template: /local/icons/waste_organic.png
value_template: '{{ strptime(states.sensor.organic_waste_pickup.state, "%Y-%m-%d").strftime("%d-%m-%Y") }}'
paper_waste_pickup_date:
friendly_name: "Paper"
entity_picture_template: /local/icons/waste_paper.png
value_template: '{{ strptime(states.sensor.paper_waste_pickup.state, "%Y-%m-%d").strftime("%d-%m-%Y") }}'
Result in lovelace using the glance card:
I started new with home assistant.
And used the twente milieu plugin.
it works. but how can i change the date to Day month year.
and where i have to do it? in configuration.yaml?
and how to change the icons. i have own icons.
Look up in this thread…
I know but don’t understand
Study the documents about templates here https://www.home-assistant.io/docs/configuration/templating/ and sensors, here https://www.home-assistant.io/integrations/sensor/.
where do i have to change it?
i don’t understand
