It would be cool if there is a function to set the TTS language on a Twilio Call. Either in the component configuration (in configuration.yaml) or even better as optional data parameter in a action/script etc. Per Default the english TTS is quite good but there are some other languages available too:
Hi Graham. Your repo seems to be down. As we are still unable to select the language for Twilio integration, I was wondering if you would be able to publish your script again?
I just changed the name to “twilio.py” an edited to post. The link to repo now works.
After 3 years, the author has not had the time to enhance the HA built in version.
