Twilio SMS Alphanumeric Sender ID
I would like to use Alphanumeric Sender ID instead of normal number.
notify:
  - name: NOTIFIER_NAME
    platform: twilio_sms
    from_number: E164_PHONE_NUMBER
Is it possible to change from_number to be Alphanumeric Sender ID
That would indeed reduce the Twilio costs as no phone number is needed. The Twilio API wants you to replace the “from” number into a “text”. Hassio should therefor also support “text” as the from number.
It would be good to have this change implemented.
I’ve added a PR for allowing Sender IDs here: https://github.com/home-assistant/home-assistant/pull/19644
