For the Twinkly integration, the possibility to select scenes and set colors would be a very valuable enhancement. I know it’s not that easy to achieve with the way how Twinkly is built - but I found out that is quite feasible.
It took me quite some time to understand how Twinkly manages its scenes. Finally I managed to control everything - not only the color mode but also the movies/effects.
The challenge with Twinkly is obviously that the scenes (movies) are only selectively transmitted from the app to the control unit. However, all movies that are in the playlist are available on the control unit. Those are then also easily controllable via API. For the colors it is even easier, because only the RGB code has to be sent.
Please find some sample Python scripts attached:
Choose a movie (needs to be added to the playlist before)
import requests
import secrets
host = '192.168.0.xx'
path = '/xled/v1'
challenge = secrets.token_hex(nbytes=16)
movie_name = input("Please type movie name:\n")
# Login
endpoint = 'login'
url = 'http://'+host+path+'/'+endpoint
myobj = {'challenge': 'AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8='}
res = requests.post(url, json=myobj)
json = res.json()
if json['code'] != 1000:
print(json)
authToken = json['authentication_token']
challengeResponse = json['challenge-response']
# Verify
endpoint = 'verify'
myobj = {'challenge-response': challengeResponse}
res = requests.post(url, json=myobj, headers={'X-Auth-Token':authToken})
json = res.json()
print(json)
# Get movies
endpoint = 'movies'
res = requests.get(url, headers={'X-Auth-Token':authToken})
json = res.json()
print(json)
movie_id = -1
for i in json['movies']:
if i['name'] == movie_name:
movie_id = i['id']
break
# Set movie
if movie_id >= 0:
endpoint = 'movies/current'
myobj = {"id":movie_id}
json = res.json()
print(json)
else:
print('Movie with name "'+movie_name+'" enabled!')
else:
print('Movie with name "'+movie_name+'" not found!')
Set color
import requests
import secrets
path = '/xled/v1'
# Login
endpoint = 'login'
myobj = {'challenge': challenge}
json = res.json()
print(json)
# Verify
endpoint = 'verify'
json = res.json()
print(json)
# Enable color mode
endpoint = 'led/mode'
myobj = {"mode":"color"}
json = res.json()
print(json)
# Set color
print(json)
url = 'http://192.168.0.66/xled/v1/led/color'
myobj = {"hue":0,"saturation":0,"value":0,"white":255,"red":0,"green":0,"blue":0}
json = res.json()
print(json)
Furthermore I managed to upload a full movie to the control unit. But here you have to “sniff” all the octet-stream movie data and its json meta data from the network first. It works, but can hardly be integrated in Home Assistant I guess…
import requests
import secrets
movie_json = {"leds_per_frame":400,"unique_id":"B68D6EA6-5E34-42A6-9402-05F8EA159ABB","frames_number": 94,"descriptor_type": "rgbw_raw","fps": 12,"name": "Snowflakes"}
movie_stream_file = './snowflakes.stream'
#movie_json = {"name":"Gradient","descriptor_type":"rgbw_raw","frames_number":120,"fps":12,"unique_id":"623A34E2-BD1A-453D-9B86-9E5BD1E52D48","leds_per_frame":400}
#movie_stream_file = './gradient.stream'
path = '/xled/v1'
# Login
endpoint = 'login'
json = res.json()
print(json)
# Verify
endpoint = 'verify'
json = res.json()
print(json)
# New movie
endpoint = 'movies/new'
res = requests.post(url, json=movie_json, headers={'X-Auth-Token':authToken})
json = res.json()
print(json)
# Upload movie
endpoint = 'movies/full'
with open(movie_stream_file, 'rb') as f:
data = f.read()
dataLen = len(data)
res = requests.post(url, data=data, headers={'X-Auth-Token':authToken,'Content-Type':'application/octet-stream','Content-Length':str(dataLen)})
json = res.json()
print(json)
