Two Buttons triggers one script, get trigger_id
I have two helper Buttons whitch call one script (not Automation). How do I get the trigger id of the Button which started the script?
alias: getTrigger
sequence:
  - action: notify.pushover
    metadata: {}
      title: test1
      message: The sensor {{ context }} triggered.
    enabled: false
mode: single
I tried trigger_id and context but I do not get a value which is always same.
Passing Variables to Scripts
Button helper entities do not have actions in-and-of-themselves… what are you using to connect the button to the script?
Also, you have disabled the action…
I have a watering system with two valves which I want to start with one script. To know which button was pressed, I need to know an id or something else.
With your hint I did:
alias: TapLinker1 EIN Zeit
sequence:
    metadata: {}
      title: test1
      message: The sensor {{ 123 }} triggered.
mode: single
fields:
  taplinker1:
    selector:
      entity: {}
    default: input_button.taplinker1_bewaesserungnachzeit
    required: true
  taplinker2:
    selector:
      entity: {}
    default: input_button.taplinker2_bewaesserungnachzeit
    required: true
what do I need to enter instead of 123 thah I get f.ex. the default name (input_button.taplinker1_bewaesserungnachzeit or input_button.taplinker2_bewaesserungnachzeit)?
i got it:
sequence:
    metadata: {}
      title: test1
      message: The sensor {{ taplinker }} triggered.
mode: single
fields:
  taplinker:
    selector:
      entity:
        multiple: true
    default:
      - input_button.taplinker1_bewaesserungnachzeit
      - input_button.taplinker2_bewaesserungnachzeit
    required: true
You have not answered how the script is being called.
The two most common options are:
  1. From a card action on the dashboard.
  2. From an automation that watches the states of the input_button entities.
