is there any possibility to create two local calendars with different ics files. Not different ics files in one calendar, but two calendars each one with a different file.
Is this possible ?
A calendar card with editing possibility would also be ok.
are you asking for two calendars pointing to url’s to ics files? or are you asking to create two calendars which can then serve up ics files?
if you want the former, look at this:
if you’re looking for the latter… i don’t know of an official way to get the ics, but there is indeed an ics for each calendar you create in .storage…
Perhaps I try to better explain what I need :
I have two different groups of people, working on two different calendars.
I need both to be accessible in home assistant, but also to be editable in ha. With only one calendar its no problem, I can use the integrated calendar and the people can create new events and all is fine. But I need two editable calendars in home assistant. Is there any way ?
Start the integrated calendar one time with 1.ics and another time with 2.ics, so people can edit them seperately. Both ics files in one calendar does not work here. The one group is not allowed to see the calendar of the others… Is this possible ?
if you’ve added the local calendar integration, that can have multiple local calendars. see:
and in the lower left, you see a + create calendar which creates another. you can see that i currently have 2 calendars already. you can create more… and have people edit different ones.
now a caveat here is that home assistant does not have a good permissions access control system, so you can’t enforce that people don’t edit the wrong calendar… you can’t enforce that one group cannot see the other if they decide to try…
