Two condition and two action in one trigger automation
Good morning,
how can I link these two automations into a single trigger?
If I leave them separated, only the first automation starts!
Why ?
It is possible to join them, the only thing that changes is the block that is set manually to one or both of the shutters.
I tried to put the second condition after the first action but it doesn’t work.
Thanks, Alberto
- alias: Chiusura parziale tapparella cucina
      value_template: "{{ states('sensor.time') == (state_attr('input_datetime.clshutestiva', 'timestamp') | int | timestamp_custom('%H:%M', False)) }}"
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: 'sensor.season'
      state: 'summer'
    - condition: state
      entity_id: input_boolean.blocco_cucina
      state: 'off'
    - service: cover.set_cover_position
      data_template:
        entity_id: cover.tapparella_cucina
        position: "30"
- alias: Chiusura parziale tapparella sala
  condition:
    condition: and
    conditions:
    - condition: state
      state: 'summer'
    - condition: state
      entity_id: input_boolean.blocco_sala
      state: 'off'
      data_template:
        entity_id: cover.tapparella_sala
        position: "30"
Just put the services beneath each other. That should do the trick.
      data_template:
        position: "30"
      data_template:
        position: "30"
yes, but I have a different condition for every shutter!
you could remove the conditions and create templates in the actions:
      data_template:
        position: >
          {% if  states.sensor.season.state == 'summer' and states.input_boolean.blocco_cucina.state == 'off'%}
            "30"
          {% else %}
            {{ states.cover.tapparella_cucina.state }} #  <-- this is supposed to be whatever the current position of the cover is so it won't move
          {% endif %}
      data_template:
        position: >
          {% if states.sensor.season.state == 'summer' and states.input_boolean.blocco_sala.state == 'off' %}
            "30"
          {% else %}
             {{ states.cover.tapparella_sala.state }}
          {% endif %}
I think that will get you what you want. I haven’t tested it so I’m pretty sure the syntax is correct but I can’t know for sure.
not work :worried:
