Stimo
(Niklas)
February 11, 2019, 8:13am
1
I am using dark sky and now I se that two sensor from the config is not longer showing, it is temperature_low
and temperature_high
that’s not working any more. The other sensors works fine
- platform: darksky
api_key: !secret darksky
language: sv
update_interval:
minutes: 10
monitored_conditions:
- summary
- hourly_summary
- temperature_low
- temperature_high
Any clue on what can be wrong?
Stimo
(Niklas)
June 4, 2019, 8:28pm
3
Stimo:
They changed monitored_conditions:
to what did they change it?
Check the docs - those sensors changed months ago…
well I checked the docs… since I added the Darksky Sensor like 14 days ago…
The 2 sensors just don’t show up.
But they are listed in the docs as:
temperature_high
temperature_low
… actually scratch that! They are valid! Mine seem to work.
You do need to have a forecast days set
forecast:
- 0
And you will have
- sensor.dark_sky_daytime_high_temperature_0d
- sensor.dark_sky_overnight_low_temperature_0d
Sensors created…
well they are not working on mine…nor on some other people’s config apparently…
I will try how you have implemented it above.
thanks,
I will try this.
I did not have a forcast set
Yeah I think it’s the reason… if you don’t set a forecast you don’t get one…
Glad I could help… sorry about first response…
Hi David,
No worries!
Thanks for the input!
Regards,
Dieter
