I’ve got two switches controlling two different groups of equipment: musical gear (mixers, effects units, etc) and amplifiers plugged into two different Zigbee switches. I call them “music_gear” and “amps”.
Here’s the crux of the problem: if the music_gear powers up/down while the amps are on, I’ll hear a loud (undesirable) thump through the speakers. So, the music_gear should be powered on before the amps are turned on and amps should be powered off before music_gear is turned off (and there should be a delay while the amps power down). To complicate things, I sometimes use music_gear with headphones (so no need for the amps). Finally, I want to be able to use these with my Alexa. So, what I’m after is being able to utter:
- “Alexa, turn on amps” triggers music_gear_on and then amps_on
- “Alexa. turn off amps” just triggers amps_off
- “Alexa, turn on music gear” just triggers music_gear_on
- “Alexa, turn off music gear” triggers amps_off, then a delay of a couple of seconds, then music_gear_off
Now, I’ve written a script for #4, and it should be pretty easy to remove the delay and make #1. What I’m stuck on is how to aggregate these with the plain on/off functions of #2 and #3. Even if I have to resort to making trivial scripts for those (so that all four operations are scripts), I’m not sure how to abstract them into two pseudo/virtual devices (or maybe there’s no reason to even do that).
Here’s what I’ve got so far (for preventing turning off music_gear until amps have been off for at least a couple of seconds). Of course, it would be nicer if there were a way to only enter that 2-second delay if the amps were on, in the first place, but I’ve got bigger issues at the moment.
sequence:
- type: turn_off
device_id: 8aacc829f75bd752214fcbb416c4ef0b
entity_id: switch.amps_switch
domain: switch
- wait_template: '{{ is_state("switch.amps_switch", "off") }}'
timeout: '00:00:10'
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
- type: turn_off
device_id: acb41716bb752f7b3349f3f1fabfa4a2
entity_id: switch.music_gear_switch
domain: switch
mode: single
alias: Music Gear Off
