Two ecobee thermostats in Home Assistant
Hi everyone,
I’ve added a second ecobee thermostat in my home but don’t know how to get it added to Home assistant. For the first one I used the API key and it just worked. Anyone have any pointers or know if it’s possible to have two ecobee?
Looking at the code it appears to be setup to handle this. You should play around with the config to see if you can get it to work
Thanks for the response. After a few days my second ecobee showed up, so my issue was probably a delay in their API updating, or Hass only checks for new thermostats every so often.
