Two entities in a lovelace history graph display separately
Hi all
I have one history card in my lovelace that is displaying its contents strangely. Generally (and as expected) most of my history cards plot multiple entries on the same axis (within a single card)—like this:
history1
However, I have one card that creates a separate set of axis for each entity—like this:
I note that the configuration is virtually identical for both cards (and I have tested to see whether using plain sensor string rather than entities makes any difference—it doesn’t).
Truncated config is as follows (its actual part of a vertical stack—and I’m using the Config UI rather than lovelace.yaml, hence the weird order):
  - entities:
      - entity: sensor.daily_power_solar
      - entity: sensor.daily_power_solcast
    hours_to_show: 168
    refresh_interval: 120
    type: history-graph
Does anyone have suggestions as to what might be causing this?
You entities have different unit_of_measurements (kw and kwh).
Good catch! Much appreciated–it should be same units; I’m check my sensor setup to try to fix it.
